911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest partnumber help oil line
Can somebody please give me the partnumber of the small oil line (arrow) at the left side of the motorcompartment. It's just under the ignition cable connector (3th plug from the front).
911 carrera coupe 1985 (euro).
Thanks,
Kees.
Old 08-26-2005, 12:01 PM
Used Up User
imcarthur's Avatar
This one?
Oil Pipe to Feed Carrera Pressure-Fed Tensioner, left, 911 (1984-89) H-107-347-06 (OEM: 930-107-347-06) $12.80
See Pelican Page
Ian
'87 Carrera Cab
Old 08-26-2005, 12:17 PM
BReyes's Avatar
I would get the pair, one for each side with metal lines too. Are you doing a full service? Are there any other oil leaks?
Regards,
Bernard
Old 08-26-2005, 01:09 PM
kees's Avatar
Hi Ian,
Thank you very much. I was looking for the oil line above (pressure fed cam oil line left). Great info at the Pelican site you mentioned.
Hi Bernard,
I'm doing a small service (changing oil, filters, brake fluid, spark plugs). There aren't any other oil leaks at all. BTW the oil line I'm talking about isn't leaking very much, it's just a little damp.
Do you think it can wait to change these oil lines?
Thanks,
Kees.
Old 08-26-2005, 11:12 PM
Somatic Negative Optimist
Gunter's Avatar
Kees: These lines sweat a little from the rubber part; if it's not too much of a leak, you can wait with replacing the line.
When replacing the line, consider installing the upgraded cam-oil-line-restrictors on both sides, here:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911M&section=engcam&page=1&bookmark=4&part_number=PEL-CAMRST
The redesigned restrictor is recognized by a groove around the outside of the hex.; it's a simple exchange. (If your restrictors have the groove, then you already have the newer ones)
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-27-2005, 07:30 AM
kees's Avatar
Porsche Crest oil lines
Thanks Gunter.
Regards,
Kees.
Old 08-27-2005, 07:49 AM
