-   -   Engine Stand Adapter Ring How TF? (http://forums.pelicanparts.com/porsche-911-technical-forum/237887-engine-stand-adapter-ring-how-tf.html)
K. Roman 08-26-2005 12:45 AM
OK, sorry for being so ignorant...How does it work? Where do I find 16 inch 3/8 inch screws? What part of the engine does attach to?
Pics PleasE!!!!
Thanks!
K.
philippeF 08-26-2005 04:46 AM
http://forums.pelicanparts.com/uploa...1125056692.jpg
maybe a bit dark, but here you can see how it is attached..
jevvy 08-26-2005 04:49 AM
a lighter version, it might help:
http://forums.pelicanparts.com/uploa...1125056978.jpg
ChrisBennet 08-26-2005 05:47 AM
Pictured is a "yoke" The engine stand adapter doesn't have the arms of the yoke, just the half ring that bolts to the motor.
I would assume that you use 3/8" threaded rod cut to length with nuts to mount the ring to the engine stand.
-Chris
EDIT: I can see now that when you said you needed 16inch long screws you must have meant 6 inch. No need for threaded rod if that is the case.
Hald 08-26-2005 06:41 AM
Here are some (poor) pictures of how I've attached mine.
http://forums.pelicanparts.com/uploa...1125062937.jpg
http://forums.pelicanparts.com/uploa...1125062967.jpg
http://forums.pelicanparts.com/uploa...1125063089.jpg
The flat black spacers are black pipe I cut to length. The shiny black part is the yoke/adapter that came with the engine stand - four arms that adjust to mate up with bolts & bolt holes, in this case, on the adapter ring.
JeremyD 08-26-2005 06:48 AM
I have a few
If you are going to use the Mainly by design one - I'd recommend spacing out just a little futher than a regular engine stand adapter goes - otherwise it's a real pain to get clutch, flywheel etc.http://forums.pelicanparts.com/uploa...1125064000.jpg
JeremyD 08-26-2005 06:49 AM
get the bolts from Home Depot/Lowes etc.
K. Roman 08-26-2005 09:27 AM
[QUOTE]Originally posted by JeremyD
[B]
If you are going to use the Mainly by design one...
I am using the Mainly one and that's where the literature said to use 16 inch bolts. Could that be right? Home Depot only had 10 inch, which already look too long!
JeremyD 08-26-2005 11:20 AM
I have 4" bolts - if I was doing it again I would space em out to at least 6 - pref 8"
You really have to measure the motor mount you are sticking them on - measure almost the other side of the carrier (from Mainly) then add the thickness of the motor mount (the yellow on mine) then add the spacer - just make sure the spacers are strong. Then you get a total for the size bolts.
K. Roman 08-26-2005 12:04 PM
Danke, Jeremy.
JeremyD 08-26-2005 02:40 PM
I took a better picture today I;ll post later
JeremyD 08-26-2005 05:31 PM
Here you go - http://forums.pelicanparts.com/uploa...1125102652.jpg
Bob Goding 08-26-2005 06:20 PM
I made the whole thing, spacers are 1" dia solid bar[which I found] drilled and tapped both ends.--plenty of clutch room.http://forums.pelicanparts.com/uploa...1125105550.jpgroom
JeremyD 08-26-2005 06:37 PM
Nice Bob - is your garage tiled?
Bob Goding 08-26-2005 07:24 PM
Jeremy,unfortunatey the answer to your question is ,-No.
I dont have a garage ,BUT---the entrance hall of the house is tiled with slate!-----As I'm an old ,hermit batchelor, no problems.
Bobhttp://forums.pelicanparts.com/uploa...1125109322.jpg
JeremyD 08-26-2005 08:23 PM
sweet!
K. Roman 08-27-2005 01:02 AM
Thanks for all the support everyone, I'll be tackling this tomorrow.
Peace!
Gunter 08-27-2005 07:17 AM
Question: The adapter ring is fastened to the two bolts protruding from the left case halve, and then four bolts from the engine stand attach to the adapter ring.
So, the entire weight of the engine hangs on two bolts from the left halve of the case?
3-400 lbs on two bolts?
JeremyD 08-27-2005 07:58 AM
yep just like the porsche factory stand...
ChrisBennet 08-27-2005 08:09 AM
The ring itself supports the case quite bit.
