Acceptable oil pressure
Looking for acceptable oil pressure for a 1980 911sc at idle of 900 rpm and at running temperature
of 180 degrees. I'm running 20/50 Brad Penn oil.
Brendan
Old 12-08-2022, 03:42 PM
I would check it at 3 or 4k RPM. At 900 RPM you are not going to get a good reading.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-08-2022, 03:49 PM
10psi per 1000rpm
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-08-2022, 04:30 PM
Thanks! Will check at 4000 rpm.
Is10 psi the same as 10 bar?
Do you know anything about upgrading oil pressure spring/thermostat spring and pistons? I don't know if it applies to a 3.0 liter sc engine or how effective this would be.
Brendan
Old 12-08-2022, 05:00 PM
1 bar is approx 14 psi
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-08-2022, 05:04 PM
Appreciate the info.
Brendan
Old 12-08-2022, 05:17 PM
Basically 1 bar per 1000RPM.
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 12-08-2022, 06:06 PM
Can’t tell much at idle from the factory gauge. Hook up an oil pressure gauge to the engine if you want to know exactly what it is at idle. As MB said 10psi per thousand rpm is what you need
it's not leaking....it's just marking it's territory
Old 12-08-2022, 06:47 PM
New-ish 911SC Targa Owner
pampadori's Avatar
I had always heard 1 bar per 1000 rpm on a fully up to temp oil.
Then I reread my owners manual and noticed it suggested pressure to be 4 bar at 5,000 rpm fully up to temp.
To get oil up to temp, you're gonna need to go drive for 20 min.
Old 12-08-2022, 08:42 PM
Functionista
manbridge 74's Avatar
The above is from the factory service manual. It assumes you have the correct sending unit and gauge. I have found the VDO gauges to quite accurate but never a bad idea to double check with a separate gauge.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 12-08-2022, 10:15 PM
This is similar to what I think I know, although I can’t recall where it came from. I was told a long time ago to look for 3 bar at 3k revs and 4 bar at 4k. I don’t think it works over 4, nor under where the pressure usually exceeds the Rev relationship
Old 12-08-2022, 11:32 PM
Well again a bar is truely equal to 14.5 psi. My 2.4 s runs a true 10psi or above per 1000. This has been the same results on all previous 911 based engines I have had
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-09-2022, 03:18 AM
pampadori's Avatar
This is from the 1982 911sc manual.
"Oil pressure in the engine is shown in bar. With the engine at operating temperature (194° f) and the engine speed of 5000 RPM the oil pressure should be about 4 bar.
A drop in oil pressure at high temperatures is normal. at idle speed with the engine oil hot it is normal for the red control light to light up."
Old 12-09-2022, 07:42 AM
lateapex911's Avatar
I'm sure zee Germans have their reasons but watching that needle under 1 at idle, considering the now super higher cost of these motors makes me hate the idea of sitting at lights! I mean does anybody else look at that thing and say, "C'mon man, just get over the 1 mark, at least!" LOL
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 12-09-2022, 09:45 AM
I'm happy it's above zero. Try driving a '69 Corvette with a 52-year-old mechanical oil gauge that's gummed up and reads zero at idle. Nearly had a heart attack on the drive home from buying it.
Old 12-09-2022, 01:23 PM
917_Langheck's Avatar
Looks like about 1.7 bar in my '84 3.2 at 180° and 900 RPM and around 4.2 bar at 3k rpm (20w50 Valvoline VR1)
Old 12-10-2022, 05:50 PM
This is a good point there are 2 different sending units available depending on what gauge you have and they could easily be overlooked. Read the range on the sending unit and make sure it matches your gauge.
Old 12-10-2022, 06:10 PM
Does altitude have any effect on how much a 'bar' is?
Old 12-10-2022, 07:24 PM
pampadori's Avatar
You will get huge swings depending on oil temp and oil viscosity.
Run 10w30 and you could be a full bar lower than 20w50.
Pressure at 150° could be much higher than at 190° as well.
My latest fear now that temps are down below freezing is causing new oil leaks.
Running too high pressure (either by running 20w50 in colder weather or by revving the motor higher than you should with cold oil) can cause oil seals to leak. The rear main seal behind the flywheel for example has pressure behind it.
I think about this ever winter when I don't want to waste my summer oil and drain it when it only has a couple thousand miles on it. Do you waste $70 worth of oil or risk leaks that require engine-out to repair?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 12-11-2022, 06:04 AM
Thats one thing that my M3 does that I really like: The tach has a variable redline. It moves higher as the oil temp warms to normal operating temp
Old 12-11-2022, 05:10 PM
