How long does a 911 engine stay "warm"?
Running through a series of compression and leak-down tests, both of which should be done with the engine "warm". I timed myself at about 15 minutes per cylinder. Pretty slow, I know.
If I start my car and let it idle for 15 minutes, the engine is painful to hold my finger tips to, implying to me that it's warm enough. However, 30 minutes later (only 2 cylinders done) the engine is now just warm to the touch, not "hot". Am I overthinking this and warm to the touch is adequate, or should I be re-starting the engine and letting it warm back up every so often - maybe in between banks?
Old 12-10-2022, 06:38 PM
oil temp to normal, 180 is a warm engine .
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 12-10-2022, 07:26 PM
Original Owner
tsuter's Avatar
Compression and leak down should be run cold.
Why?
Cold numbers don't lie......
Hot is OK...but hot numbers lie.....
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 12-11-2022, 03:12 AM
Titanium User
Always on a cold motor is what I've done and been told.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 12-11-2022, 05:45 AM
Original Owner
tsuter's Avatar
Sellers and Dealers do it hot....buyers do it cold....muhahahahaha!
tsuter
Thaaaats Right!!
Old 12-11-2022, 07:01 AM
How long the engine stays hot depends on ambient temps, summertime I needed 2 hours to fiddle with anything, winter maybe 45 mins.
180° is Hot -
Warm (metal for instance) is anything that can be handheld comfortably for over 5 mins…85°-105° is a generally acceptable “tepid” range.
As like stated measuring Cold vs Hot is a variable, as heat will increase/expand where as cold will retract/shrink the tolerances measured.
So, is it the rational being it would be best measured at midpoint or Warm…?
Operating at normal temp (180°ish) will essentially “seal” any worn rings/valves/guides while driving under normal conditions, until cold again - e.g. leaking oil into cylinders. If I’m at 175psi w/8% LD…I can expect 5 mins oil smoke from the tailpipe if she sits more than 6 weeks and zero oil smoke on startup after 2 weeks.
Old 12-11-2022, 10:20 AM
