-   -   street allignment specs help (http://forums.pelicanparts.com/porsche-911-technical-forum/237969-street-allignment-specs-help.html)
911S77 08-26-2005 01:41 PM
Hello,
After some suspension works I'm going to do allignment tommorow. But I'm little confused with all the numbers...
I run 195/65/15 front and 215/60/15 rear tires.
Suspension set to euro height.
Please tell me yours optimal specs for street/spirited drives setup.
Thank you
/Jack
Rot 911 08-26-2005 01:45 PM
1/8" toe in, -1 degree camber. I am sure others will differ, but this is a good all around set up.
911mot 08-26-2005 02:30 PM
From Euro owners manual
http://forums.pelicanparts.com/uploa...1125091760.jpg
johnsjmc 08-26-2005 04:31 PM
Street only, and long tire life factory settings above are fine. I aim for 1/2 neg camber front,1 1/2 neg rear ,6 1/2 pos caster.Slight toe in front slightly more rear toe.1/8 toe is way too much,some even prefer slight front toe out for quicker turn in.
