-   -   On a crab'd 3.0...how much backfiring is "normal"? (http://forums.pelicanparts.com/porsche-911-technical-forum/238012-crabd-3-0-how-much-backfiring-normal.html)
svonkampen 08-26-2005 07:53 PM
Ok when I drive my car in the morning, I start her up and let idle at 1500 rpm for about a minute.......
Then I start driving, and she will fart fat ones for about the first 3 to 5 minutes of driving, then she settles down ..........also if I gun her and then down-shift she will fart quite a bit.........
My heat-exchangers are new ssi's so the problem is not there...Also TRE did a rebuild on the carbs.
Keep in mind that in order to run carb's on a stock 3.0, they need to be run rich.
Is this normal behavior?
thanx,
SvK
svonkampen 08-26-2005 07:57 PM
Bob Tilton,
Does your car do this?
SvK
bob tilton 08-26-2005 08:39 PM
tansplanting the heart of a beast will involve dialing in little nuances over the course of time as you re-adjust to a new organ.
i had this issue and several others which took about 1000 miles to resolve. my back firing was the result of a lack of back pressure due to the dansk duel out sport muffler. i replaced it with a single out dansk and the problem was solved.
in re: to start-up, the carbs need about 30-60 seconds at 1500 rpm to clear its throat(s) first thing in the morning. it's fine once i take off. all other start-ups are fine.
have you cked for exhaust leaks? i had one at the SSI flange to the muffler flange. Resolved with new gaskets.
how's your engine temp?
svonkampen 08-26-2005 08:46 PM
Bob the surgeon ;-)......thanx for responding
my engine temp gauge is always super low.....maybe broken?
btw, I have single-out Dansk....will check muffler gaskets....
SvK
svonkampen 08-26-2005 08:58 PM
"in re: to start-up, the carbs need about 30-60 seconds at 1500 rpm to clear its throat(s) first thing in the morning. it's fine once i take off. all other start-ups are fine."
So when you drive to work and leave car for 8 hours, then start up for drive home,,,,no back-firing?
SvK
bob tilton 08-26-2005 08:59 PM
yes - i recall from your pics that you had a single out exhaust.
what you did was a major upgrade with a lot of things done at once. 99% of the work has been completed and only time will tell what that 1% needs to be done.
sounds like it just needs some fine tuning which is to be expected.
what are your thoughts on the suspension?
svonkampen 08-26-2005 09:02 PM
Love the suspension.......she is so stable at 110mph........you gonna upgrade?
SvK
bob tilton 08-26-2005 09:03 PM
yeah - all other start-ups are fine after the morning start-up which is also combined with a couple days of sitting. it was much like my '83 rx7 which required the same start-up procedure.
dd74 08-26-2005 09:04 PM
"Crab'd"
In this case, I suggest you take your car to one those free clinics; not TRE...:D
bob tilton 08-26-2005 09:05 PM
i can't justify the susp upgrade right now considering everything is new "down there".
my next upgrade will be a LWB ST replica. ;)
svonkampen 08-26-2005 09:06 PM
Wish I could give you more feedback on suspension.....I am not a schooled driver YET....so I take it pretty easy in turns........But like I said , Night and Day difference at high-speed..
BTW Dave at TRE said: "The '68 suspension was just plain awful"
SvK
svonkampen 08-26-2005 09:07 PM
I think that includes the prior year as well.......
svonkampen 08-26-2005 09:36 PM
ST huh ?
" ST/GT was permitted to run an oversize engine for racing in Group 4, the FIA allowing Porsche to increase bore but not stroke. As a result, displacement was up to 2247cc, bore having been stretched by 1mm (to 85mm), stroke remaining unchanged at 66mm. Designated Typ 911/20, the highly tuned engines were equipped with twin-plug heads, camshafts from the Carrera 6 and special Mahle pistons."
wow.......what color? ;-)
svonkampen 08-26-2005 09:42 PM
ST rear...for Surgeon Bob,
http://forums.pelicanparts.com/uploa...1125117731.jpg
bob tilton 08-26-2005 09:46 PM
these are my initial thoughts as i have just been having them within the last few days:
1 start with a carerra and backdate it
2 69-73 front fenders
3 plain front bumper (not split S or RS)
4 1 piece rear bumper
5 fuchs up front, minilites in the rear
6 cibie hood lites (2 pair)
7 RS interior with dark green leather
8 slate grey exterior
9 no decals
this would require selling my car and starting new.
svonkampen 08-26-2005 09:50 PM
it will be interesting too see what your car will fetch.....but how will you live without a working Porsche during the build?.....that is just torture. Just a mere 6 weeks without my ride and I was ready to start Prozac...
SvK
svonkampen 08-26-2005 10:10 PM
DD74,
heheheehehe...i couldn't figure out what you were talkin' about
"crab'd" ....free clinic ! hahahaha
....but my car is suffering IBS ;-)
SvK
ianc 08-26-2005 11:38 PM
So, umm... What happened to the CIS injection that came with the 3.0? You could always 'uncrab' yourself...
ianc
RoninLB 08-27-2005 01:30 AM
all below depends on ignition, cam, etc.
the gas has to be in a state for efficent combustion. CHT becomes a factor with a rich idle circuit. I've found that a very rich circuit needs a bit higher CHT than just a rich circuit to preventing start up bs. Very rich needs about 175degF for no bs at all, rich needs about 160degF.
svonkampen 08-27-2005 01:36 PM
Ronin,
I have no idea what you are talking about ;-)
Please speak english...so this dummy can understand........
SvK
