Plugs - What a diff!
On the left is a Bosch W7DTC 3-electrode plug with about 5000 miles on it. On the right is an NGK BPR6ES (copper) with about 5000 miles on it. The Bosch showed some caked on carbon which you can't see here very well. The NGKs had no carbon on the electrodes at all. (the black on the NGK electrode is dirt/grime from removing).
Quite a difference , yes? The only other variables were that I replaced my rotor and cap when I installed the NGKs.
Would you say that the main difference is a better spark due to new cap and rotor? Or are the single electrode plugs just a way better plug?
-Steve
'87 Carrera Targa
Old 08-28-2005, 08:44 PM
I use NGK's in every car I own. They are the best plug IMHO.
Mike
'77 911 3.0
'94 Mustang GT
'77 911 (soon be a real live racecar!)
Old 08-28-2005, 10:51 PM
jluetjen's Avatar
Re: Plugs - What a diff!
Unfortunately, from a design of experiments perspective you messed things up by replacing the cap and rotor, so there is no way to tell what the cause was. If the rotor and cap were worn, it could very likely have changed the spark to the level where it would cause what you see.
You can correct the problem though by cleaning up and regapping the Bosch plugs and putting them in for another 5000 miles, and THEN comparing them to the NGK's.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 08-29-2005, 03:44 AM
armandodiaz's Avatar
Back in the 80's when I used to work on the line, I couldn't tell you how many problem cars came in with ign problems. It would always boil down to people installing plat plugs. These cars were made for copper plugs. Install the Bosch Super plugs and you'll notice how good they work.
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 08-29-2005, 06:16 AM
Excellent picture, thanks.
Old 08-29-2005, 07:43 AM
No prob.
I wouldn't normally change my plugs so often but since I have to do my smog test this week, I didn't want to take any chances.
-Steve
'87 Carrera Targa
Old 08-29-2005, 08:28 AM
Unregistered
sammyg2's Avatar
Those two plugs have different heat ranges, right? that might have something to do with it. Maybe the one on the left was too cold. Anyone?
Old 08-29-2005, 09:45 AM
jluetjen's Avatar
Good point about the heat ranges. In order for the comparison to be meaningful, both plugs have to be of comparable heat ranges.
John
'69 911E
Old 08-29-2005, 10:59 AM
Those plugs have the same heat range.
Mike
'77 911 3.0
'94 Mustang GT
Old 08-29-2005, 09:48 PM
wow.
and NGK BP6ES is one step colder than plugs for rich carbs. Meaning I ran BP7&8 ES with CIS.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-29-2005, 10:10 PM
