carrera fuel line, (BAT and AN fittings)
the black and gold fittings are from BAT in florida. I used part # (1)F90 1606 for the filter, (3) FS 1606 one for each rail and one for the damper.
I used (3) -6 AN straight hose ends and (1) steel AN tee.
Also (1) 45 degree -6 AN hose end for the pressure regulator and (1) m16x1.5 to -6 steel adapter from BAT for the pressure regulator because it seemed almost impossible to get the threads running with a straight black and gold fitting ffrom BAT. I used six feet of -6 hose. this was enough to do the regulator to damper line 15.75"
fuel filter to tee 34"
passenger rail to tee 12.25"
driver rail to tee 9.75"
there are cheaper ways to do this, welding adapters to your cut off carrera fuel tubes with fittings, also Bat has steel m16x1.5 to -6 fittings, Or a local shop can press fittings for you.
This is the only way I know where you could get parts and make your own without any welding or crimping, also reusable and replacable hose.
OF course your HOSE length may vary.
Old 08-28-2005, 02:04 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Nicely done Jerry. Looks great.
Thanks for posting all of the details. It seems that with a search, many people will find good alternatives to the dreaded expensive factory fuel line.
What's up with the blue Magnecor wires? Don't you know red is fastest? Blue looks cool.
Kevin L
Present: '86 Carrera, ‘89 Corvette Z51 6spd
Past: '87 Carrera, ‘79 911 SC widebody racecar
Old 08-29-2005, 10:02 AM
Nicely done!
now tell me about the Jeep in the background
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 08-29-2005, 11:42 AM
that jeep is a friends,
here's one of the steel adapters from BAT. Would have put it up before but I had to get a new camera
Old 08-29-2005, 01:35 PM
Used Up User
imcarthur's Avatar
Jerry
Cool. What was your total cost?
btw glad to see you survived the hurricane . . .
Ian
'87 Carrera Cab
Old 08-29-2005, 01:47 PM
180 something +shipping
I'm going to make up another set with the welded fittings and put em on the sale board sometime.
as for the hurricane, it just got a little windy, 120 miles west of New New orleans. we dodged the big one I believe
Old 08-29-2005, 02:17 PM
armandodiaz's Avatar
Jerry:
did you replace the fuel return hose from the dampner? The one I have circled in red:
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 09-09-2005, 06:27 AM
MBruns for President
JeremyD's Avatar
Just for an example... I took my fuel line to Amazon Hose in Tampa. I paid around $100 - $120 for my line. Actually for both lines they redid.
When I was there last for an Oil line R & R [$35.00 ] There was another Carrera fuel line. It had a tag for Dave White Autosports... I asked and they said - yeah - no problem - we do those all the time for Dave...
line in yellow
Old 09-09-2005, 07:56 AM
one other pic I should add for future searches good pic of line from regulator to damper
Old 10-12-2005, 07:25 AM
Used Up User
imcarthur's Avatar
Jerry
Do you have a link to the BAT website for the fittings? A Google search produces nothing but stuff about bats.
Ian
'87 Carrera Cab
Old 10-12-2005, 07:35 AM
http://batinc.net/
Old 10-12-2005, 07:40 AM
what was your total cost for the parts?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 10-12-2005, 07:46 AM
Used Up User
imcarthur's Avatar
Thanks, Jerry. This is an early spring job for me.
So all of the colorful connections are compression fittings? Did you source the hose through them too?
Ian
'87 Carrera Cab
Old 10-12-2005, 08:18 AM
$180 plus shipping.
all those fittings are just push ons
BAT has the critical fittings to fit the rails, fuel filter and damper and pressure regulator if you go that way. They're all the same size. The cad steel adapters are a cheaper way. 16mm by 1.5 female to dash six male, see the connection on the regulator in the pic for an example. it's easier to go that route if you don't want to mess with the regulator or damper, or rails. The Aluminum gold are the BAT fittings. (expensive).
I got hose and straight dash six hose ends and tee at
http://amstreetrod.com/400040ERL.php4
They seem like decent guys.
Old 10-12-2005, 09:32 AM
bfrenz's Avatar
I called them awhile ago and the fittings are something like $25 a piece. Not cheap.
1973 914-6 3.2 Motronic
Old 10-12-2005, 10:04 AM
I just finish my lines and it's worth the extra $$$ not to go through the aggravation. One thing about Amazon, they only carry Teflon center lines. I wasn't too comfortable about the Teflon sealing over the fittings. If you do want to use the original hard lines, I'd get the rubber center then take it to Amazon to crimp. Just my suggestion, take it for what it's worth.
Armando Diaz
Old 10-12-2005, 10:16 AM
jwetering's Avatar
We did this job the hard way recently using a factory part. BIG BIG BIG job. Benefit of doing itthe hard wayis you get to replace the lines in behind. Ours were in really bad shape.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 10-12-2005, 10:17 AM
greglepore's Avatar
This is a great thread. I really want to replace all of these lines, b/c I've now got a rr regulator due to turbo and because I've disturbed the lines. What do you do with the lines that mate to the hardlines? I'm still unclear about how those get replaced.
Greg Lepore
85 Targa
Old 04-06-2006, 04:40 PM
I replaced EVERYTHING so I can't help you.
Armando Diaz
Old 04-06-2006, 04:49 PM
greglepore's Avatar
If you did everything, how did you do the line from the firewall hardline to the filter inlet.
Greg Lepore
85 Targa
Old 04-06-2006, 05:08 PM
