930 trailing arm torque to cross-tube
Gang:
What is the torque spec on the bolt that goes through the trailing arm where the trailing arm mates to the body at the cross-tube. I'm showing 74 ft/lbs in my manual??? But that seems low for that size bolt. Can anyone verify that spec? Brian |
The M 14x1.5 grade 10.9 bolts show 60Nm(~44.25lb-ft) for an'83
but for '84 -'87 w/ self locking nut it shows 100Nm((~74lb-ft) |
Thanks Bill. That is what I was showing. Just wanted to make sure.
Brian |
| All times are GMT -8. The time now is 08:24 PM. |
