WydRyd's Avatar
Heater Blower Relay?
Hi,
I'm told there's a heater blower relay in the engine compartment? Can anyone post a pic to it please?
I need to check that a couple of pins are jumped on it, which allows my footwell auxiliary blowers to function permanently without the engine compartment blower.
Also, should the footwell blowers stay on, when operational? Mine seem to intermittently work Does that mean they are on their way out?
Thanks in advance
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-30-2005, 12:48 AM
Used Up User
imcarthur's Avatar
The one in the middle with 3 holes on the left & the defogger relay on the right.
If both of your footwells are intermittent at the same time, then I would suspect the relay.
Ian
'87 Carrera Cab
Old 08-30-2005, 03:18 AM
WydRyd's Avatar
Cool, thanks!
Any idea which pins need to be jumpered so the footwell blowers can be powered by the centre console switch?
Merv
'89 911 Turbo Cab
Old 08-30-2005, 03:47 AM
Used Up User
imcarthur's Avatar
This is the wiring that has been posted:
Terminal 12 - Hot from Front Fuse Panel "key on"
Terminal 7 & 8 - Hot from Fuse 2 (Rear Panel)
Terminal 3 - Hot from Fuse 1 (Rear Panel)
Terminals 5 & 6 - Output to Main Blower
Terminals 4 - Output to Heat Controller (the dreaded Footwell link)
Terminal 2 - Ground
I have not confirmed it.
Ian
'87 Carrera Cab
Old 08-30-2005, 03:55 AM
