Red Wire at Battery - 2.3 Amp Drain - 82SC
Still trying to track down why I'm getting a 2.3 Amp current draw.
What I have done:
• Verified with a multimeter that I’m seeing a 2.3 amp current draw when connecting my probes between the positive lead and the positive battery post
• Pulled every fuse one at a time (no effect on the current draw)
• Pulled the alternator and disconnected: still seeing a 2.3 amp draw
• Disconnected the red wires from the positive leads and tested each individually
o Main thick lead – no current draw
o Red wire that splits into two wires – 2.3 amp draw
o Red wire (single) – 2.3 amp draw
So the questions are:
• Why am I getting a 2.3 amp draw out of the red wires?
• Where do the red wires go to?
Michael
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 07-25-2005, 06:37 AM
Two red wires seem to go to the ignition switch and one to the various lights. It's odd that both red wire circuits draw the same current. Is that what you're saying?
Old 07-25-2005, 06:59 AM
I was surprised as well to find that both wires have the same draw.
Anyone have any guesses on how to track this gremlin down?
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 07-25-2005, 07:08 AM
Just a guess, but Porsche's have the turn signal on while parked feature. Have you checked that?
Old 07-25-2005, 07:14 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
remove all fuses and check for draw. if none, replace one at a time until draw returns. if draw is present with fuses removed, trace hot unfused wires to their destination.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-25-2005, 07:40 AM
Did you pull the fuses in the engine compartment?
www.exeterautosupply.com
1976 911S Targa
Old 07-25-2005, 08:17 AM
I removed the fuses one at a time (including engine compartment). I'm thinking from what I'm hearing everyone say that maybe I need to pull all fuses, then begin replacing one at a time.
Question:
If I pull all fuses and I still have current draw, what are the implications? Do the red wires run to anything directly (i.e. unfused)?
Michael
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 07-25-2005, 08:19 AM
My current flow diagram for a 82 model 911SC shows two red wires going to the ignition switch. The other goes to #18 fuse on the fuse panel, then it goes to the #10 pin on the main harness connector. From there it goes to the #30 pin on the Oxygen sensor relay. Hope that helps.
1976 911S Targa
Old 07-25-2005, 08:33 AM
Only circuit unfused is the ignition circuit, according to my diagram.
1976 911S Targa
Old 07-25-2005, 08:35 AM
I also show the wire that goes to the #18 fuse, has jumpers from the #18 power supply side (before the fuse) to #17 fuse, #19 fuse, and #20 fuse. 17 controls the hazard flasher. 17 has jumpers that feed power to power window relay, parking brake and seat belt warning light and horn relay. 19 fuses power supply to the head lamp washer relay (if equipped). 20 fuses power to the A/C relay and A/C cooling fan motor relay.
1976 911S Targa
Old 07-25-2005, 08:52 AM
UFLYICU
ZOA NOM's Avatar
Ignition switch would be a likely culprit. Could be worn enough to leak a few amps.
prc-racing.com
Old 07-25-2005, 09:24 AM
some circuits are unfused.
2.3amps is a big drain. Even a bad unfused relay should only draw 400-600ma. The fresh air front flower is also unfused.
If one of the red wires from the battery terminal goes to the ignition sw main feed and it's drawing 2.3 then maybe I'd head in that direction.
Maybe toasted switch contacts feeding a circuit when in "off" position?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-25-2005, 09:44 AM
wild guess
2.3amps leads me to think the rear window heating element may be triggered.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-25-2005, 09:48 AM
2.3 amps isn't a big drain, it's 27 watts which is about what a turn signal or taillight bulb draws. You should see a circuit resistance of about 5 ohms.
Old 07-25-2005, 11:12 AM
Tonight, I'm going to pull some fuses and see what happens.
I'm wondering, my power windows work whether the key is on or not. I'm wondering if something could be going on with them pulling current. Previous owner did some strange things to the car. If like Hladun says that 2.3 amps isn't much, then maybe...
I'm also going to figure out where the red wires go to and see if I can't disconnect then and see what happens.
Ronin and Zoanas: I'm hoping your thoughts are not correct on a bad ingition switch. That would be a PITA to fix. Yes, it's in the book of 101 projects but still a PITA.
DMARV: Thanks for pointing out where the red wires go. That will give me a big head start tonight on where's it's hitting the fuse box. Most appreciated.
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 07-25-2005, 11:22 AM
UFLYICU
ZOA NOM's Avatar
Yeah, it would be a PITA. It would make sense that the switch could be worn with use, but on the other hand, parts that get little use can corrode and fail, so it's a tossup. You'll know much more when you start attaching loads to the battery one at a time.
prc-racing.com
Old 07-25-2005, 02:13 PM
911mot's Avatar
Do you have a stereo or amp that might be drawing current?
Also try pulling all the courtesy bulbs - glovebox , engine, trunk etc
Got anything plugged into the cig lighter?
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 07-25-2005, 02:55 PM
The routine should be around 40-60ma for a proper system. 100ma is a noticable battery drain.
2,300ma is a big drain.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-25-2005, 03:20 PM
2.3 amps is about what a bulb draws, not a big drain by comparison to other electrical components such as motors. What are you talking about? If you're referring to what the current should be on a system that doesn't have a short then I agree with you. But mtelliott has already said he has a 2.3 amp drain.
Old 07-25-2005, 03:36 PM
Senior Member
Might pull the 14 pin plug off of the engine in back just in case. Would eliminate one last variable if the fuses do not do anything.
JoeA
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 07-25-2005, 03:48 PM
