Silly power window question. 81SC
I just replaced my alternator and now my power windows work WITHOUT the ign. on where as before I had to turn the key to get power to the windows. I did find a wire that wasn't hooked up as it was shoved down a little. I just figured I had pushed it down during removal. Now I think it wasnt hooked up before cracking it open.
Can anyone tell me whether you have to have the key on to work the windows in your 81SC? Also, i am somewhat retarded when it comes to reading electrical schematics. Is it even possible to have corrected this by attaching a wire to the alternator? Thanks!
Scott Clevenger
1989 BMW 325ix 190K
1981 911SC 110K miles
http://www.pelicanparts.com/gallery/clevy70911T/
Old 08-26-2005, 09:44 PM
On my 82 SC the ignition needs to be on for the power windows to work.
-Mac
Old 08-26-2005, 10:14 PM
not having seen this before & according to an elec diag
the window motor gets it power from a trunk relay. The red/black 30wire in the relay gets its power from the ignition sw in only the on & start key position.
Is another "on" position circuit operating in the "off" key position? That would point to the ignition sw. The radio is on another ign sw connection.
If not then something is feeding power into the circuit at the other end of relay#30 into #87. #87 relay connector feeds into fuse #16. Fuse#16 feeds the window switches, then to the motors.
I'd check that fuse #16 terminals without the fuse connected.. if I had trouble finding #16 I'd pull fuses till the windows stopped working, hopefully. If the circuit was hot after the fuse then pulling the fuse won't prevent window operation with fuse pulled.
party hearty
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-27-2005, 02:35 AM
fireant911's Avatar
My 81SC also requires no key in to operate the windows. I seem to remember a thread from a couple of years back discussing the same issue and there seemed to be no concensus here: even within the same model years some folks had windows that worked without the ignition being on while others did not.
Daryl G.
1981 911 SC - sold 06/29/12
Old 08-27-2005, 03:45 AM
Driver Ed's Avatar
On my '82 SC, the key must be in for the windows to work. Interesting that the two 81's don't and the two 82's do in the tabulated results so far.
2000 Porsche 911
1982 Porsche 911 SC Targa
Old 08-27-2005, 03:53 AM
I have had an '81 and a '79 both required the ignition be on to operate windows. I am not sure that anything on the alternator replacement would change this operation.
Kevin
'79 Coupe
Old 08-27-2005, 05:04 AM
Mothy's Avatar
Send a message via AIM to Mothy
Mine is an 83SC and my windows work all the time - doesn't matter if key is in or not. However, the sunroof does requires the key turned.
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 08-27-2005, 05:18 AM
Thanks for the responses. I guess I'll check things out regarding the ignition switch as it does feel somewhat worn out. I havent found any other things working now WITHOUT a key, so I think the switch is OK. After that, I'll just enjoy my new feature. Chalk it up as a friendly electrical gremlin.
On a side note, after experiencing the symptoms of that crazy voltage regulator and over-charge issue, last night I made a plug-in-the-cigarette lighter voltage meter that velcros under my ashtray until I can install a permanent gauge. I used an old cell phone charger, solder, duct tape (of course) and VDO gauge. I just hope I didnt fry something and cause this before getting the alternator changed out.
Scott Clevenger
1989 BMW 325ix 190K
Old 08-27-2005, 08:01 AM
jdowty3's Avatar
My 83 requires the ignition on to power the window switches. Looking at the electrical diagrams, all of the US SC years should work this way.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 08-27-2005, 08:09 AM
Information Junky
island911's Avatar
Sounds like a stuck (fused/welded) relay contact.
Old 08-27-2005, 09:29 AM
I'll check out the relay described by Ronin LB. Now I'll get out the schmatics and get a feel for them. Thanks to all!
Scott Clevenger
1989 BMW 325ix 190K
Old 08-27-2005, 09:34 AM
I could be wrong on the above and power may come from a constant hot. So the relay may be fused shut?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-27-2005, 10:15 AM
911mot's Avatar
On my 84 carrera if the drivers door is open you can operate windows and sunroof. This is supposed to happen.
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 08-27-2005, 10:48 AM
kqw kqw is offline
Get in, close the door, start the car, shut it off. You should be able to operate the windows. Now, open the door and close the door. You should not be able to operate the windows.
The Fox
Carrera
Old 08-28-2005, 08:50 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
The windows work on my 80 SC without the key in the car at all. I thought i had an electrical gremlin cause my interior lights never worked either. I tried to debug it but got fed up and said screw it. Dont drive on the track at night anyway. At least I know Im not alone with the window thing.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 08-29-2005, 08:36 PM
kqw correctly describes a properly functioning system ( at least for US spec cars of this vintage). I've posted on this before.
Culprit is usually a bad plunger door switch that allows the PW relay to "always" be energized. Not correct.
Leads to fast battery drain too for garage queens.....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-01-2005, 09:32 AM
