Jubbie's Avatar
Oil pressure now normal along with blood pressure
So,
After my rebuild 1000 miles ago, I only noticed that my oil pressure was not low. After reading the forum, I learned that 60 psi at 2000 rpm was not normal. After fretting, checking my 964 cam towers oil restrictors, fretting, checking my relief valves, and having to drive home staying below 3000 rpm (man that sucked), my oil pressure was still high.
Well, after reading something that Warren Hall (Thanks Warren) wrote. I determined that I have a 0-140 psig gauge and a 0-75 psig SC sender. I figured that the 930/02 engine should (at least by PET) have a 0-140 psig sender. It is easy to see since the range is written in bar (0-5 bar or 0-10 bar) on one of the flats of the nut that you tighen the sender to the case. I guess the PO did something non standard.
So, I grabbed the old sender off of my 2.7 and now I am feeling much much better.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 09-01-2005, 08:00 PM
