-   -   Help! What I done did? (http://forums.pelicanparts.com/porsche-911-technical-forum/238907-help-what-i-done-did.html)
Mike O'Meara 09-01-2005 11:08 AM
It's a 72, I removed/cleaned/painted,etc the oil tank and lines, although I did not remove the breather lines from the body. Upon restart I've got a massive leak from the air cleaner housing. Could I have reversed the breather lines? I'm just getting the car ready for the painter and don't need to be messing around with an oil leak!:(
slater 09-01-2005 11:13 AM
Is it possible you overfilled the oil tank?
Mike O'Meara 09-01-2005 03:16 PM
I think that's what I did. Thinking back, I didn't drain the sump, and when I finished the job I put 9 quarts back in! The oil, before more leaked out, was nearly to the top of the tank! Goes to show the danger of starting a job and not finishing it until months later. You lose track of where you were. Thanks.
gassy 09-01-2005 03:27 PM
I did the same thing...no one here is ever alone.
