-   -   ALU trailing arm upgrade 69E ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/238921-alu-trailing-arm-upgrade-69e.html)
Bobboloo 09-02-2005 03:13 PM
Thanks Warren good data point to know.
911pcars 09-02-2005 04:05 PM
I'm not sure this has been verified, but perhaps inner 4-bolt CV joints can be used with outer 6-bolt joints. I think the axle splines are the same.
Can someone verify?
"We make the following modifications to the arms and shocks: 1- cut down the dust sleeve so it just caps off the rubber bump stop...."
Rather than preform surgery on the dust cover, I just removed them for the needed clearance around the rear shock tower (Koni Sports). This may or may not be necessary with narrower shocks.
Sherwood
midlife 09-02-2005 04:23 PM
Interesting thread.
I have aluminum arms on my '69. (Not my install.)
The shock dust covers are rubbing on the shocks. It looks like I need to remove them.
Thanks for the great info.
Bobboloo 09-02-2005 04:55 PM
No go. The splines match but the diameter of the 6-bolt flange is smaller.
I also checked to see if you could have an axle with a 6-bolt CV on one end and a 4-bolt on the other. This also doesn't work because the axle diameter of the 6-bolt is also smaller.
Zeke 09-02-2005 07:18 PM
Originally posted by midlife
Interesting thread.
Remember that the top of the dust cover is a functional part of the mount. That's why Dave cuts them real short as opposed to removing them altogether. If you can find a thick washer the same ID and OD as the top of the cover, you can susbstitute that. That's what I did. It really doesn't get all that dirty way up inside there unless you drive a lot of dirt roads or something like that. I was going to remove the fronts too, but thought better of that since a lot of things bounce around in the front wheel well and could nick the shaft of the shock.
An added benefit to exposing the shaft is to use a ty-wrap on the shaft to guage total compression, or total travel. You'd probably find that you use it all anyway. But for a short skid pad test.............
911SCfanatic 09-02-2005 07:51 PM
Remember, there was a structural change to the rear cross member in 1972. I think the shock interference issue is limted to pre-72 installs. I've reviewed many threads and only the pre-72 people seem to complain about the upgrade relative to the shock issue. Can someone confirm this?
randywebb 09-02-2005 08:59 PM
think that's right....
