interested in 911's
carrera's Avatar
door locked but opens
Can someone shine a little light onto this problem?
The locking mechanism locks and you cannot open the door from the inside, but from the outside the door opens.
Have removed the panel and cannot see any issues.
An 88 carrera with power locks.
thanks
Old 09-02-2005, 04:55 PM
Will program for food
ghnat's Avatar
I would check the door lock mechanism. Maybe a piece is broken.
Here are 2 pics of my drivers doorlock hardware removed. Hope this helps.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 09-02-2005, 07:22 PM
Retired Member
Charlie V's Avatar
I had the same issue on my 82 Targa. After studying how the latch mechanism works it became obvious what my problem was.
The striker on the spring loaded rod part was not hitting the trigger for the latch. I VERY carefully bent the stiker to line up with the trigger. Works like new again.
See ghnat 2nd pic. The spring loaded rod is on the right of the pic. In the car this is the top of the lock mechanism.
I had to remove the glass and glass rails to access the latch mechanism properly. This is an all afternoon job. Test that the latch works properly in the locked and unlocked positions.
Again - VERY CAREFULLY bend the striker.
Good luck.
Old 09-02-2005, 08:16 PM
interested in 911's
carrera's Avatar
Thanks greg it does help, is everything here in working order?
I was trying to fix this without removing the mechanism these pictures might help me do it.
86 Carrera
88 Carrera
95 Carrera
and just one more...
Old 09-02-2005, 08:17 PM
interested in 911's
carrera's Avatar
Hey Charlie thanks for stopping in. This trigger you speak of seems to be too far from the rod but it also seems stuck should it be able to move?
86 Carrera
88 Carrera
95 Carrera
Old 09-02-2005, 08:22 PM
Retired Member
Charlie V's Avatar
Yes. Clean and grease all the moving parts.
Old 09-02-2005, 08:29 PM
ghnat's Avatar
Everything was in working order - just darn dirty!.
I still gotta find out what grease to use when I FINALLY get the car back together...
I have much bigger pics if you need. I can email them to you if you want.
Greg Hnat
98 Jeep Cherokee
Old 09-02-2005, 08:56 PM
