LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
WydRyd's Avatar
HP Junkies - Clash Of The Titans...
Not sure if this review has been posted before, but it's certainly worth a read
http://europeancarweb.com/features/0404ec_titans/
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-01-2005, 05:11 PM
911Velocity's Avatar
Re: HP Junkies - Clash Of The Titans...
I have the mag and its worth a read.
Best regards,
Gerry
84 911 Carrera (Supercharged), 67 427 Vette , 67 XK E-type Rdstr., 56 Vette
06 Cayenne Turbo S, 08 Vette Coupe, 57 Vette, 65 Chev Nova 327 4spd
65 Chev Nova 385 Race, 85 Chevy Rollback
97 Ford Exp. EB, 90, 91 Toy PU
Old 09-01-2005, 10:17 PM
WydRyd's Avatar
The specs of that 996TT entered by Protomotive is 862.8HP @ 1.327 bar
Check out the dyno graph at the bottom of his URL:
http://www.geocities.com/protomotive/dynos.html
Over 800HP from 5Krpm's to 7.5Krpm's. Absolutely Mind blowing!
Merv
'89 911 Turbo Cab
Old 09-02-2005, 01:34 AM
WydRyd's Avatar
Merv
'89 911 Turbo Cab
Old 09-02-2005, 01:42 AM
beepbeep's Avatar
Hmm...impressive power but that dyno graph looks like something kids overhere get when they install Garrett GT40 on 2L four-pot with hot cams.
Heaps and heaps of peaky power. I wonder if those track times wouldn't be better with a little bit less boost and smaller turbochargers that start boosting earlier.
Thank you for your time,
Old 09-02-2005, 03:45 AM
WydRyd's Avatar
Errr... what's quicker spooling that twin Garrett GT28R's?
Merv
'89 911 Turbo Cab
Old 09-02-2005, 04:15 AM
Me like track days
Craig 930 RS's Avatar
That thing would be a PITA to drive
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 09-02-2005, 06:11 AM
beepbeep's Avatar
A pair of Garrett GT17's?
As you probably already know, there is a difference between "quick spoolup" and "low boost treshhold".
You can have a turbocharger with very low bearing friction and low shaft intertia, but it won't save you from late boost treshold and long as impeller/turbine is too big for given engine volume. If turbo is mismatched, there is no ball bearing in the world that will rectify it.
With other words, sleave bearing turbo with smaller turbine will start boosting sooner than GT28RS "Disco Potato" even it will have higher bearing friction.
(Worthless knowledge: "Disco Potato" is a nickname for GT28RS, it's compressor map looks like a dancing potato)
P.S.
BTW, article states that they used "T3/T4" hybrids in Promotive car, not GT28RS?
T3 is old school turbo that usually boosts around 3000 RPM on 2L volume...T4 compressor is biggish compressor (I guess they used T3 turbine and T4 compressor) and 1.6L volume per snail would push this quite high up the rev range.
Impressive output though.
Old 09-02-2005, 08:42 AM
