I've got a severe oil drip after the oil t'stat opens up. Messy and smoky when hot from my headers.
What is a fair cost I should expect to pay to have a specialist Pcar shop drop the motor and do the typical oil tstat and sensor replacements? Say 5 hours plus parts?
"And there's no cure like travel to help you unravel the worries of living today. when the poor brain is cracking there's nothing like packing a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes" |
That would be a starting point. In fact that's just what JWE charged to do the same for my car. They found several other things that needed doing while the engine was out, and since I agreed to have them done, the bill ended up substantially higher. Which is good; at least I got everything done with only a single engine drop.
You might check your oil lines for leaks. You don't have to drop the engine if that is were your leak is coming from. If it is your oil thermostat gasket, there are ways to get to that without dropping the engine.
86 911 coupe 2001 VW TDI |
really ! I'll do some more searching.
symptoms: no dip until hot..then DRIP DRIP DRIP puddle.
I removed my cis to rebuild and did the tstat then, also do the pressure sender, and breather gasket while your there. I will help you do it if you want to tackle it.
Donnie Currently Porsche-less.....
GOT TURBO..
They can tell what you need before they drop it. To R&R an engine heres some recipes from when i was at the shop....
R&R : 6 hours plus oil Rear mail engine out : 1hr plus $45 oring Tower area reseal(termostat oring,crank case vent gasket, oil press idiot light) : 1.0 hr $65 parts Oil cooler seals/test cooler:1.5 hours plus $25.00 seals Main shaft seal : 1.0 hr plus $ 45 seals VC gaskets : 1.0 hr plus $ 45 for the kit Injection reaseal : 1.0 hrs Plus $90 boots and gaskets Front pulley seal : 2.5 plus $60 seals and gaskets Hope this helps. Find out their hourly rate...Make sure they call you before they do anything to it. Keep track and or write it down... Good luck.. Hope this helps |
