Grease gun and Elephant bushings
I had some Elephant Poly bronze bushings installed on my rear spring plate bearing. After six months I decided it was probably time to add some grease, so I went out and bought a nice grease gun at an auto parts store. When I try to put the nozzle onto the zerk fitting it seems to snap right on, but then grease oozes out around the nipple when I try to inject grease. Do I need a special gun, or is there something I am missing?
Thanks,
rickdm
rickdm
'87 Carrera
'91 Miata
'78 SC (ex)
Old 09-03-2005, 09:34 PM
Zeke's Avatar
That's generally what happens if you aren't exactly in line with the fitting. If that's not possible due to the way they were installed, remove the fitting and replace with an angled one. The grease WILL go into the bushing if you get the gun square to the zerk.
Old 09-03-2005, 09:39 PM
I think I got it pretty squared up with the fitting, so I am hoping some grease got in there, but it sure seemed to ooze out a lot.
Thanks,
Rick
rickdm
'87 Carrera
'91 Miata
'78 SC (ex)
Old 09-04-2005, 12:51 PM
that MAY indicate that its full of grease already.
i dont think they take that much grease to begin with
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 09-04-2005, 01:49 PM
Chuck Moreland's Avatar
Jason
Is it coming out between the gun and nipple, or out from the bushing?
If the gun/nipple do as per above a be sure the gun is properly snapped on to the nipple. If from the bushing, this is normal. As soon as the grease grooves fill, the excess wil squeeze out. Doesn't take much.
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-04-2005, 03:04 PM
Chuck, it is coming out from between the gun and the nipple. I can get it to snap on, but it still pivots around and I have not been able to get it to go on any further. I will try with some vise grips to see if I can get the nozzle to go on a bit further.
rickdm
rickdm
'87 Carrera
'91 Miata
'78 SC (ex)
Old 09-04-2005, 03:13 PM
Forget the vice grips just hold the gun pushed by hand against the zerk . If grease won,t go in then I would change the zerk fitting as it may be clogged or defective. They are standard parts at any part store and quite inexpensive.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 09-04-2005, 03:17 PM
If this is happening on all the zerks, then it's not the zerks. Try a new gun tip. You can buy the tips seperately.
Old 09-04-2005, 03:40 PM
Information Junky
island911's Avatar
Sounds like the wrong size fitting on the gun. (?)
Old 09-04-2005, 04:34 PM
OK, here is my next stupid question 'they come in sizes?'. I was under the impression that grease fittings were a universal one size fits all. Is the zerk fitting on the bushing a particularly small one?
rickdm
rickdm
'87 Carrera
'91 Miata
'78 SC (ex)
Old 09-04-2005, 06:03 PM
AFAIK, the normal "nipple" style comes in one size only.
There are other styles of grease fittings, but they look entirely different. You could not confuse them with a standard zerk fitting/gun.
Old 09-04-2005, 06:34 PM
Information Junky
island911's Avatar
It's been a long time since I've used a grease gun, but I do recall using one up with some funky (non-standard) coupler. (didn't work so well - grease ozing like you describe)
a grease gun from an auto parts store ought to be just right. (unless it's from discount China) . .when it snaps-on it should only swivel . . . no rattle/side to side.
It could be you're feeding it too fast, too.
Old 09-04-2005, 07:25 PM
It's a lot easier if you have a flexible line on the gun. Ones with solid tubing are really hard to get lined up right, especially if there are space issues.
Charlie
'67 S Tangerine
Old 09-04-2005, 08:32 PM
84toy's Avatar
I have a couple that ooze around the nipple too but it still pumps in to the bearing at the same time. If grease comes out from around the edges of the bearing, you know its getting in there even if it does not seal well around the nipple. Big rag handy.....
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 09-04-2005, 08:52 PM
billyboy's Avatar
nipple sizes
no comment necessary! yea, I know I'm adolescent.
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 09-04-2005, 09:20 PM
