quick ride in project
Moving to the Pittsburgh area from Wisconsin and the movers asked me if the 71' project was driveable enough to get it in the truck. So.... after they left, I fired it up and took a spin up the road. Now we are talking basically astriped shell so I didn't want to push it but the "does it run" challenge was impossible to resist. Someday I'll be able to take it for a spin "legally".
Old 09-07-2005, 07:48 AM
adamred's Avatar
Where are you moving to in WI? My home state, go back several times a year....
Adam,
2019 BMW 540i
Old 09-07-2005, 09:01 AM
Moving from Wisconsin(LaCrosse), to Pittsburgh area.
Old 09-07-2005, 09:46 AM
Non Compos Mentis
Ah, yes.
The first couple of drives around my rural area, with no headlights in the buckets, no rear window, and lots of other parts in boxes sitting in the garage. Once the car will move under it's own power, the urge to drive it is irresistable.
Old 09-07-2005, 10:30 AM
I know the feeling. I did a full resto on my 74 and had it stripped down to a shell. Once I got the engine and tranny in, I had to fire it up...right. Well once it was fired up and running, I might as well see if I have the clutch and shifter coupling installed properly. So I threw in a mike crate and took if for a spin around the block. I went fairly slowly since I hadn't got around to rebuilding the brake system. It was great inspiration to get me excited over the next 12 months it took to finish the car.
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 09-07-2005, 11:39 AM
Gon fix it with me hammer
svandamme's Avatar
i've been running amok in mine for the past weeks nothing electrical is done yet, and doing speeds good enough to loose my licence... also in the country side. curvey roads, allready annoyed a few bikers because they are short of rubber in the corners
they can't find enough straight road to get rid of me
it does look more completed, it's only the electrical crapola i haven't gotten around to doing
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-07-2005, 11:58 AM
It definitly adds to the motivational aspect of the project. I went from look at all the work I have left, too...hey a little and a bit more there and I can get this done.
Old 09-07-2005, 12:12 PM
