Reuse SC Valve Cover Gasket?
Did a valve adjustment on '78SC and reassembled with the green silicon valve cover gaskets. On a warm up run prior to topping off the oil, I discovered a leack from the left lower gasket.
I took the turbo cover off to check to see if I had missing a piece of grit, or something. I saw that some portions of the silicon sealant stuck to the cover. I have several options, it seems, which are acceptable:
Can the gasket be reused (the sealant flaked off in small area)?
Run a bead of gasket sealant?
Buy another valve gasket?
1978 911SC (not black, Mocha Brown)
Old 09-05-2005, 02:47 PM
kqw kqw is offline
Probably no issue using the gasket as it sounds like you have not run the car for long periods of time.
Try it and see but I think you'll be fine. However, the lock nuts and washers are a different issue. Those you should replace.
The Fox
Carrera
Old 09-05-2005, 04:01 PM
Crusty Conservative
silverc4s's Avatar
New gaskets, unless you have the silicone (red) ones, IMO..
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 09-05-2005, 04:03 PM
