The "what" and "where" of Calibration Fluid (MFI)?
What is this mystery fluid:
Calibration fluid (eg. Bosch # 5 701 301 725 or equivalent) It is for use in MFI pump storage/maintenance, per the MFI thread on this BBS: Quote:
I always heard that Marvel Mystery Oil was a good replacement. You could probably use transmission fluid too. You just need something lwith a low viscosity too keep moisture out. Good Luck.
I heard from Monty at Redmond European, that he uses ATF. I just didn't know if calibration fluid was something special.
You may want to send Lubemaster a PM. This right up his alley.
Here's a tidbit from an oil co.... "Calibrating fluids are simulated fuels with properties similar to diesel fuel and/or gasoline. These specially developed fluids are not only safer to use, but are formulated to meet tighter, more demanding specifications required in the manufacturing processes used by the fuel system component manufacturers when building fuel pumps, fuel injectors and fuel, air and oil filters. VISCOR Calibrating Fluids are more suitable than commercially refined fuels for use in manufacturing processes due to the following: Precisely controlled Viscosity and Specific Gravity specifications Higher, safer Flash Points Lower aromatic hydrocarbon content" |
I'm going to speculate. "Calibration" fluid won't evaporate and leave a varnish residue, only a very light protective layer of preservative oil.
EDIT: A quick Google turns up that most calibration fluids are for just that, calibration of instruments that use oil. In diesel engine work and testing, apparently it is a way to test volume, etc. safely without the use of actual fuel. So, the weight (in chemical terms) is the same, but the properties are not. There are different types of "calibration fluid." |
transmission fluid in an mfi pump??? it better not be swepco, or it will stick everything shut, that stuff is nasty!
Anybody have a clue where to buy the stuff? I am going to recondition my MFI pump and this stuff seems to be the ticket...
PM Lubemaster....
It is most likely an R&O mineral oil, low viscosity (maybe a 10W) is my first guess. R&O stand for rust and oxidation inhibited. Not really the best for service but will act like a nice protectant. I will look into it further and get back to you. In the mean time, I may have a product that would work great for you. It is a flushing oil that many folks have been using to fill new gearboxes and pumps when put in strorage. If you would like, I will send you some gratas. PM me your shipping address.
What you are looking for is the calibration/test fluid that is used in a diesel fuel injection pump when tested. There are several manufacturers, and any of them will work. The MFI pump on the 911 engine is an adaptation of a Robert Bosch diesel injection pump, and the governor assembly is similar as well. The test oil is non varnishing and will not cause problems in extended storage.
Go to http://www.diesel.org/dealer/us.html click on your state, you should be able to find a facility near you that can help. |
STIJN,
I meant Automatic transmission fluid. Ever here of it? You know not all cars have manual transmissions. |
Here is something I found. This may help you out.
http://forums.pelicanparts.com/uploa...1126216095.jpg |
| All times are GMT -8. The time now is 06:58 PM. |
