-   -   mfi idle on max, still lean on idle? (http://forums.pelicanparts.com/porsche-911-technical-forum/239845-mfi-idle-max-still-lean-idle.html)
svandamme 10-15-2005 12:09 PM
it just won't deliver at idle if i lean out the main, both the thermostat or the main adjust, if i lean those , the idle is lost... i can only maintain idle with the hand throttle, and even then , it's very, very rough , and my main is still too rich, it's drivable, sort off, but it's no fun... lm1 calls 10:1 at best under load... without load... 17 and sometimes more... not good.... coughs and spits way to much so as soon as i figure out which kidney i'm going to sell, left or right one ... the pump goes to Koller for a rebuild...
cmcfaul 10-16-2005 08:45 AM
Good call on the rebuild. Do it while there are still people who know how to do it. It will come back properly calabrated and should be good to go.
Chris
73 911 E
svandamme 10-29-2005 06:59 AM
just went to the garage, yanked the pump and injectors of
was a little tempted to go for a little drive, the weather is so nice, it's almost like a mild summer...
decided not to drive, no use heating things up when i want to get those injectors out and stuff, besides, it's cramped working space as is , with a warm engine, it's just like an oven...
dripp dried the pump, then pulled the solenoid and panels off and was amazed how much oil still was in there... all out now, stuffed the whole thing in a box, some isolation foam... got some collegues who work in our Nurnberg office, so no shipping cost to Koller, i'll ship it from office to office till it arrives in Nurnberg
"anyone going to Dusseldorf?" then "anyone going to xxx??"
practical benefit of working in a multinational company :D
Grady Clay 10-29-2005 07:19 AM
Stijn,
What is the condition of the throttle bodies? It would be appropriate to have them flow calibrated at the same time.
What are you going to do about the thermostat? It would be best for them to install it on the pump, properly set. I would recommend you get a new left (at least) heat exchanger and the correct air tubes to the thermostat.
While the pump is off, set the engine to Z1 #1 and pull the distributor. Take it to someone with a good old distributor machine. Get everything set and run in. Have them make you an advance chart of the actual measured advance curve and vacuum retard. This will be very useful when you get everything back together. You will be able to set the timing static and be very close at 6000.
Remember to take your batteries out.
Good for you. I know it is expensive but you will have this fixed and properly running for many years to come. Fun driving ahead.
Best,
Grady
svandamme 10-29-2005 11:01 AM
my TB's are fine, they seem to be rebuild before, no plastic bushings, no play either, they were dirty though , the bores for the screws and the vacuum were clogged so i cleaned them and flowed them with a vacuum cleaner
i have good throttle correlation , no problems there
as for heat exchanger/thermostat, i'm planning to ask Koller if they can rebuild mine with the enrichment solenoid... they have been quite strict on prior emails, when i was asking about changed engines ( before my rebuild) and they answered with "no! we only rebuild according to ze Bosch spec" ... but can't hurt to ask about this enrichement thing... paying customer with pump in their shop , might get different answer than someone just firing an email in their mailbox... i'll see what happens...
the Dizzy is fine as far as i can tell, advance and retart behaves according to the factory manual , allready over budget so i'll leave it at that for now
believe me , if i had the cash , i would ave just dropped car and engine and the whole thing off at some restoration shop, with a note saying :
"please strip nekkid, and rebuild concourse state, don't forget the radio and all the little stickers, i'll be back in a month to pick her up..., K?thx!"
i just don't have the bankaccount to do that...
sballard 10-29-2005 06:29 PM
Stijn,
If you are considering Grady's suggestion about installing a conventional thermostat, you could just have a local welder attach a short length of stainless tubing on the heat exchanger to connect up to the new thermostat. I did this and it was a lot cheaper than buying a new exchanger. You can see the location of the factory tubing and hose on an MFI engine in the recent thread of the early 911 assembly line.
Steve B
Peterfrans 10-30-2005 01:39 AM
Steve,
Stijn has no heat exchangers on his car, fabricating something to feed the original setup with warm air is not so easy.
svandamme 01-18-2006 02:45 AM
fyi , just received my delayed xmas present by UPS
my pump , all nice and rebuilt by Koller
fresh thermostat&shutoff solenoid, the idle adjustment thingie is fixed and 6 brand new injectors
looks almost brand new
just ordered a new mfi belt , and some little things
and should get the pump installed soon-ish...
i'll make some pictures when i get it home
svandamme 01-19-2006 10:25 AM
http://forums.pelicanparts.com/uploa...1137698272.jpg
http://forums.pelicanparts.com/uploa...1137698355.jpg
cheapo digicamera , flash is no good, and no flash ain't to shabby either...
Grady , came up with an idea for the thermostat
not sure if it will work , but it's well worth a try
here goes :
i plan to use the low pressure in the engine bay , created by the fan and the intake
so i'll attach the hose to the thermostat and the engine tin , as would normally be attached
then i'll fab up something below the engine tin , so it pulls air from some hot area headers or lower valve covers, not sure which ones yet ,as i'm not sure how much heat i need to make the thermostat tick..
then i'll check if the normal engine bay has low enough pressure to draw air from down there
i'm no expert, but it's just the reverse from the stocksetup ( fan blowing air into the HE's, and from there , to the thermostat
it's no direct source either , so i don't think it needs much air movement to work...
does anybody know , at what temperature the MFI thermostat is supposed to click?
Peterfrans 01-19-2006 11:11 AM
This won't work as there is no significant pressure difference between the engine bay and the area below the engine bay at standstill. When driving it even could be the other way around.
The easiest way around this is the supertec solution as this enables you to manually adjust the enrichment. Another option would be going back to at least the left head exchanger in stead of the headers you are now using. Also still possible is Grady's solution with the screw.
Peterfrans 01-19-2006 11:14 AM
or, you could rig a hair dryer to the thermostat and it is just a click of a switch on the dash
Grady Clay 01-19-2006 11:22 AM
Stijn,
Great that you now have all ready to go back together.
First let’s talk about the thermostat. Am I correct there isn’t any tin heat exchanger on the left headers? If there are just the bare headers, find some tin and make yourself a small “heat exchanger” just for the thermostat. It should be at the “bends” in the headers toward the front as they are the hottest. Make it too large; you can always waste the extra heat. Use the standard supply ducting behind the distributor and below the tin you can make an adaptor to reduce the hose to a smaller size. From your custom “heat exchanger” use the OE air plumbing to the thermostat.
Part of this effort is to maintain the original warm-up characteristics of the system. Having too much heat results in the thermostat turning off sooner; preventing gasoline diluting the engine oil. This is easy to modulate by simply wasting some of the excess hot air. If the thermostat turns off too soon, all that happens is you get a little “lean rough running” during warm-up. No big deal. If too rich and too long, you get oil dilution that can be catastrophic.
OK, on to the next issue.
How long did you run the engine after the rebuild before you pulled the MFI pump? Kilometers, hours, liters of fuel? What service did you do? Change the oil? Torque the head nuts? Check the cam timing? Adjust the valves? Check the ignition advance curve and set the timing?
Right now you are at a critical CMA point.
When you have all these “little” details attended, you want the engine to start and run satisfactorily. You will then need to do some brake-in both from the fresh engine rebuild and the setting all winter – very important. You should try and not adjust your fresh pump unless absolutely necessary. If you do, keep perfect track of your adjustments. As the engine, MFI system, ignition and other all settle in, you want to chase the adjustments with full knowledge.
I posted on someone else’s thread (Canada?) about MFI brake in. Find that link.
There is a lot to do before you first crank the engine. There is a lot you shouldn’t do when it is first running. You are not permitted to take Peter for WOT runs. Hehe. Some careful running is necessary.
Let’s devise a carefully thought out plan.
Best,
Grady
svandamme 01-19-2006 11:40 AM
i didn't run it to much , max 1.5 tanks of gas probly less, maximum 150 kilometers (many WOT runs and very rich , obviously)
and 2 oil changes (1 after initial 20 minutes, another one after i needed to pull the tank to fix the bracket)
nothing torqued yet, no cam timing or valve adjust yet
did check the curve and timing , that was fine
i spoke to the rebuilder, he said drive it 1000 clicks, then valve adjust, no need to torque anything, i trust him , he restores a historical 911 racer for Porsche finland, and does mostly early 911 racers
Koller did not mention any special instructions for running the pump , i told them it was for immidiate use, so i assume they did not do any special storage treatment
in fact, the pump is capped off all over, the fuel connectors still smell like fuel from testing
i figure i'll put the pump on , prime it with oil, time it
and then spin the engine with the lm1 & synchrometer at hand
while at the same time keep an eye out for everything as one would during the first startup of a fresh rebuild...baby steps so to speak...
for now , i'll just use a manual heat gun to control the thermostat untill i decide on a final solution , Koller installed the thermostat, and laquered the bolts for warranty check , so i'de be stupid to pull it off and mod it , untill at least i know the pump checks out otherwise...
agreed on not messing with the settings, if everything is as one would expect from a by the book rebuild, it should run pretty close to perfect out of the box...and definately a hellofalot better then when i pulled it off a few months ago
PS , i don't think Peter is up for another WOT run anytime soon :D
svandamme 01-21-2006 03:13 AM
ńews from the fronline :
pump is installed, major cursing and swearing during the belt install phase...
key to on
left it to build up some pressure
then cranked
no joy
took about a minute and a half worth of cranking , in short bursts, till it fired, while i made sure i had spark (carbcleaner)
then it went , sounded great, nice steady idle
revved nicely , no popping or hesitation
after about 3 minutes, used the heat gun to switch on the thermostat, rpm went down , but was a bit to soon as it hesitated when i pulled the control rack
but LM1 confirmed, AFR of 14 ish
checked for leaks, none, checked the oil , bit low, topped it up
now i'll pull it from it's parking spot , get some fresh air and maybe do a short drive
Peterfrans 01-21-2006 03:25 AM
Great news! Glad you decided on the rebuild route for your pump. Still enough time to dial everything in, fix some details, sort out the thermostat issue and be ready for summer and classic le mans
beepbeep 01-21-2006 03:28 AM
AFR 14:1 @ idle sounds promissing. Please post your AFR findings, (I never fiddled with MFI. It would be nice to see how fresh MFI works AFR-wise.)
svandamme 01-21-2006 07:35 AM
well, didn't do much fiddling yet, had some vibration in the wheels i wanted to take care off, so i took my fronts off, and decided to get all the brake dust off them , and all the lead, and redo it
by that time, rain and gusts, so no more driving
LM1 , before the pump rebuild :
http://forums.pelicanparts.com/uploa...1137861212.jpg
LM1 , after the rebuild , no tuning so it's not perfect yet
shutoff not connected yet, and thermostat operated with heat gun :
http://forums.pelicanparts.com/uploa...1137861289.jpg
there is a clear improvement, and i'm sure it will get better with some effort
next time, i'll go through the procedure , as last time with the throttle bodies, they're now setup from last time, when the pump was way to rich, so the idle isn't strong when warmed up , need handthrottle to keep it running... but i know how it works now
disconnect all linkage, and configure everything like that
then reconnect the linkage, and make sure the linkage does not open the valves when it should be at the stops...
tedious , but it works really well, with the pump working fine, it should be an open and shut case
just been comparing the xy plots in logworks...
the old one was all over the place, no clear concentration of plot points.. but the new one , there's allready a concentration of points in the 13/14 region , for the mid range RPM
i'm confident i'll be able to get that looking more like a fat line of plotting points as i get the throttle bodies setup for the new pump output...
beepbeep 01-21-2006 08:18 AM
Stijn: best way to get consistant AFR vs. RPM plot is to do one long WOT pull on straight road, in 4:th gear. Start with full throttle from 1000 RPM and let it accellerate to 6000 RPM or so while logging.
Scatter-diagram is also good statistical tool but you need to log lot's of data. You seem to have data dropouts on AFR chanell on last diagram, do a smoothing on them.
svandamme 01-21-2006 08:40 AM
yeah i know , but the car had been not driven for 2-3 months
so i was still beeing carefull , checking things over and doublechecking again for fuel leaks and what not
since i had the shaking in my wheels, high speeds in 4th gear were not really a safe thing to do... let's hope the rebalancing of the wheels fixes that, so i don't have to chase suspension/bearing gremlins
Peterfrans 01-21-2006 08:46 AM
Also check if your front wheel bearings are tight
svandamme 01-21-2006 08:52 AM
i did, no movement at least not on first sight, i'll get to that shaking next times, i'll do some suspension refreshing as well, that hasn't been touched at all, so i'm sure a few new bushings here and there are in order.... have to take the back end off anyway , something not right, right wheel sticks out to much ,though the car does run straight if left alone, weird)
the plan is to do the frontend first, then tackle the rear end when i do the first valve adjust , mini engine drop, and do the bushings and stuff while i'm in there
klatinn 01-21-2006 11:30 AM
Hi Stijn,
Your second LogWorks plot has a lot of AFR spikes. If you notice, all the spikes go into the lean direction. That indicates ignition misses, not electrical noise. I would check your ignition system. While the car was sitting you might also have collected some condensation in the dizzy. That could explain it. It could also be that one injector is not spraying right.
Check the "lambda bar" on the LM-1 at idle to see if you have a lot of oscillations. That's also an indicator for uneven mix distribution/missfiring.
Smoothing the graph won't help you much with those spikes. It even can lead to a misrepresentation of the data because the spikes get averaged into the correct readings.
Regards,
Klaus
svandamme 01-21-2006 11:41 AM
thanks Klaus, i'll definately check the dizzy , could well be condensation , my exhaust was bellowing white smoke , held my hand to it , and it was wetness , nothing else, so it's safe to assume there was similar condensation in the dizzy itself
btw, what to do about condensation in a dizzy?? ideal time to upgrade it with an Optical trigger??
i also still need to properly gap my sparkplugs for MSD
the injectors are fresh, checked out by Koller, so i think those are fine
klatinn 01-21-2006 12:02 PM
Stijn,
Condensation in the dizzy will disappear once the engine is properly warmed up for a while. But you mention MSD. Are you using an MSD box with MSD coils or just the stock CDI with an MSD coil? If the latter, that might be the problem. The MSD coils are optimized for a high energy CDI, which the Bosch unit is certainly not. Therefore the spark duration with stock CDI and MSD coil can be too short to properly fire. I ran into that problem before when I had a 2.2 MFI.
Regards,
Klaus
svandamme 01-21-2006 12:07 PM
MSD with Bosch blue coil, i don't really notice any misfiring or popping though , it sounds and feels smooth...
i'll keep in in mind, but i've got a number of things to do first , this was just an initial run , i do have to get my throttle bodies setup properly ... and then baseline again
klatinn 01-23-2006 08:55 AM
Hi,
When you hear popping you have severe missfires. The LM-1 will pick up single missfires or incomplete combustion even at high RPM. You can't feel or hear it, but it will show up in the logs.
Regards,
Klaus
svandamme 01-23-2006 09:01 AM
that's pretty sweet , i just went through my old logs, they didn't have the spikes, not to this degree, so most likely your first guess about condensation is spot on , and it will go away with a bit more driving...
got the day off on thursday , it's getting fun messing with the car now , clear progress, no more big costs to be expected ( knock on wood ), and no more big downtime, i can work, drive, fiddle with some things, drive some more, etc etc... really helps for my motivation...
