rjb rjb is offline
Question 911 performance air intakes; Good or Bad?
Are the preformance air intakes I see out there worth it for the money? What manufacturer would be recommended fora stock 911?
Do they make any difference?
89 Carrera Cab
Old 09-09-2005, 07:45 PM
they definately sound cool if you are into that type of thing.
a little of this + a little of that
Old 09-09-2005, 07:59 PM
I had the Air tech one and it didn't seem to make a difference.
Old 09-09-2005, 08:05 PM
Unregistered
sammyg2's Avatar
Are you talking about filters, or actual intakes?
If you are taling about filters and such, the only ones that will make any difference is the ones that will bring in cold air. If you can get cool outside air to your engine instead of hot engine compartment air without bringing in rain or dirt, your engine will like it.
Even those will make a small difference, just about anything else is fluff or bling.
If you are talking about larger bore throttle bodies or something like that, I've heard mixed results on a stock engine. Some say it helped, some say it did nothing.
You might get a better evaluation if you post a question about a particular brand or style, more to go on.
Old 09-09-2005, 08:25 PM
rjb rjb is offline
Does K&N make a solution for the air intake? If so, where can I purchase one?
89 Carrera Cab
Old 09-09-2005, 09:30 PM
Wavey's Avatar
see this recent thread:
Experimental data for Cold air intake
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 09-10-2005, 04:34 AM
efhughes3's Avatar
Mine went on not for performance, but rather to clean-up and balance out my motor after removing A/C and heater blower. Can't wait for the next valve adjust and/or plug change
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 09-10-2005, 06:04 AM
Diss Member
Quicksilver's Avatar
Porsche didn't screw up the aircleaner housing. There is nothing to be found there. By altering it you can change the sound though. Some of the intakes can reduce power but you probably can't feel it.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-10-2005, 06:42 AM
