Pelican brake cooling kit Question
A quick look at the kit shows one hose, is that right ?
Thanks, Jack
I would rather be driving
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
One hose per side...
Donnie Currently Porsche-less.....
MBruns for President
as Don says - one per side...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
So, the Pelican one includes the rotor backing plates? don;t forget those...
I don't think the backing plate in the kit is the same as rotor blockoff plates Jeremy, it is the plate that attaches to the strut ears and connects to hose.
There is one hose 26" long, cut it in half? There are NO instructions.
Thanks Jeremy, I got the backing plates. Jack |
IMHO - Worthless to buy a kit without those. You'll just end up cooling the inside of the wheels.
Ya, its called a blocking plate, i got 2 of those.
Jack Last edited by Jack Gresham; 09-09-2005 at 07:10 AM.. |
The more I look at the pics i think i may have to cut the hose in half, its 26 " long and it appears to be about 12 " from the scoop to the top of the rotor. The way it was packed left no room for another 26" hose.
Waiting on a call back from Pelican... Jack |
bump
Cut it jack - no way you'll use 26" of hose unless you attach to the front valance.
you will probably end up using about 6-8 inches if my memory is correct.
AHH I missed the initial question. Now, I assume you bought the kit, it arrived and there was one section of hose that is 26" long. Yes, cut it in half and use one section on each side.
Brake cooling gone bad....
I guess you are doing the DE in a few weeks eh? Sorry my engine won;t be broken in by then...
