Question on front shock replacement
I am replacing the front shocks on a 74 Carrera with Koni Classics inserts. The instructions say to put 50ml of oil in the strut housing. What type and weight of oil is recommended.
I used a mixture of antifreeze and regular motor oil, there should be some in there already..
I've used ATF. It's to help the heat transfer from the insert to strut body.
I used motorcycle fork oil.
| All times are GMT -8. The time now is 10:08 AM. |
