jpc1818's Avatar
Unhappy Kick me down when Im riding high
So I have driven my 78 911 up and down the block three times. I had a ton opf oil. I decide to take the engine appart and reseal it (rocker shaft seals, main seal, new clutch, ect). Just got it back together and the oil leaks are gone, . However, I have white smoke out the tail pipe. I shut it off it goes away, start it up it comes back, when you smell the smoke it stinks bad. So gents what could it be????????????
1989 C4 Coupe
1975 911 carrera 2.7rs Sold
1978 911sc Sold
2001 Boxster S
Old 09-10-2005, 04:38 PM
Wider is Better
wholberg's Avatar
First, check that you don't have a serious oil leak dripping onto the heat exchangers, then I would check your oil level and make sure it is not overfilled, then take it on a 10 mile drive on the highway at night. I'll bet it's just oil that needs to burn off.
Wider is Better
Old 09-10-2005, 04:42 PM
What he said.
Old 09-10-2005, 05:38 PM
oil sliming the inside of the exhaust system. takes time to burn away. go out at night and lay down a smoke screen until it clears up. be sure it's not overfilled too.
206 637 4071
Old 09-10-2005, 05:46 PM
87coupe's Avatar
Why at night? Just curious.
ßrandon
Old 09-10-2005, 06:09 PM
jpc1818's Avatar
so we dont think it could be anything more serious?
1989 C4 Coupe
1978 911sc Sold
2001 Boxster S
Old 09-10-2005, 06:34 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
So your neighbors don't call the authorities on you for being a gross polluter. I picked up a customers car that did the same thing allmost all the way across the valley. Smoked like a mosquito truck, you wouldn't believe the dirty looks I was getting from everyone. Of course you could just replace the muffler.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 09-10-2005, 06:35 PM
jpc1818's Avatar
Yea, the oil level is fine I cjecked while it was hot and running, it was actually a bit low, so I added 2 quarts. I also found that two of my spark plugs are not getting a spark, so cap rotor and wire I must get.
Cheers fellas
James
1989 C4 Coupe
1978 911sc Sold
2001 Boxster S
Old 09-11-2005, 04:04 AM
