-   -   how do I drill out steering lock for track? (http://forums.pelicanparts.com/porsche-911-technical-forum/240328-how-do-i-drill-out-steering-lock-track.html)
hkspwrsche 09-10-2005 02:36 PM
Suggested by Widebody911 but, I'm not sure how to do this.. I assume its to keep it from failing andlocking on the track???
North Coast Cab 09-10-2005 03:09 PM
Going from memory I believe there is a steering lock mechanism in the back portion of the mechanical portion of the ignition switch. You need to remove that piece to eliminate the steering locking.
John
hkspwrsche 09-10-2005 03:56 PM
yeah I got it all out.. didnt know the preferred way to remove it. Just hack it off the side of the ignintion switch or if there is actually a place to drill that will cause it to all drop out...Thom had phrased it as "drill out"
hkspwrsche 09-10-2005 04:45 PM
I removed the cap on the side and drilled itenough that the thing fell out... curious how everyone else removed it.
