-   -   Alternator Rebuilder or High-Amp New Unit (http://forums.pelicanparts.com/porsche-911-technical-forum/240729-alternator-rebuilder-high-amp-new-unit.html)
cab83_750 09-12-2005 11:04 PM
My alternator is not dead yet! 12.4-12.75v at 2-3K rpm! I will be thinking about just replacing the regulator, but...
to be on the safe side, I am open to everything being 'kinda' new. So, does anyone recommend a reputable rebuilder in the Ventura/LA County areas?
Thanks.
Also, has anyone bought and used the new high-amp alternators our sponsor carries?
RoninLB 09-13-2005 12:05 AM
does the high amp have larger dia windings?
cab83_750 09-13-2005 06:31 AM
I do not know the specs. I just thought it would be an upgrade if I were to buy a new one.
JackT 09-13-2005 06:46 AM
Any armature place can rebuild it. THey are not that complicated. I would take it off yourself and install it yourself.
scottb 09-13-2005 11:02 AM
Cab: Call Foreign Alternator and Starter in Northridge. I had mine rebuilt there two years ago for $75. It's a hole in the wall shop, but the guy knew what he was doing and, so far, it's been working perfectly.
818 772-1700 (near the corner of Reseda and Parthenia, IIRC.)
Jeff Higgins 09-13-2005 11:27 AM
Local autoparts stores can get rebuilt ones. Autolite supplies rebuilt Bosch units for around a hundred bucks.
