Webers with spacers - Too Cold?
I've been running my 71 911E lately in the warmer weather (it was over 80 today) and after my 10 mile drive to work I can touch the carbs and they are still cold. I installed a set of PMO "plastic" spacers/insulators as a preventive measure to keep them from getting too hot in the summer. It takes some spirited driving to get the motor to warm up. Are they running too cold? Would removing the spacers make them warm-up quicker?
The carbs should remain cool while the engine is running. Lots of fuel evaporating (and subsequent cooling effect) within them and lots of fresh airflow.
Ultimately, if the carbs are warm/hot, the airflow within is less dense. This isn't good for power or for consistent air/fuel mixture.
Chet Dawes 1971 Porsche 911T Coupe 1974 Porsche 914 2.0L 2004 BMW 330i ZHP Sedan 2008 BMW X5 4.8i Sport |
More Likeable IRL
in cooler weather ive actually seen condensation on my old 40mm webers. i was told it meant i was not driving it hard enough...
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
cold carbs
When my kids were racing karts running on Methanol we would get ice buildup on the carb. 4 cycle Briggs with "stock" carbs with sometimes 3/16 solid ice. If you are burning an Ethanol blend gas you may see ice if you look quick enough after shutting the engine off. Very dense fuel charge is good for performance.
I think I need to Sync the Carbs. The motor does pop and hiss a bit. I'll post an update after I smooth them out. Now back to that throttle cable issue and clutch adjustment.....Ahh the joys of owning and rebuilding old Porsches...
Gratuitous Car Shot....Speedster!
From what I understand the spacers are to insulate the carbs from engine heat after the engine is shut down. The fuel boils out of the float chamber and into the intakes when the carbs heat up, making for hard starts.
-Wade 1972 Targa, nothing matching. Looking for motor 6124265 and transmission 7720299 |
