3.2 915 Guide tube wear & clutch judder
After replacing my clutch I have had bad judder in first gear. So bad it will jump out of gear, even on normal take-off. It's ok in reverse and pulling away in second you can give it plenty and no judder.
I gave it 500 miles with no improvment - actually it got worse. So today I pulled the motor and found nastiness inside the release (throwout) bearing. It is badly scored, and so is the guide tube. I have got a pic but it's from my phone so apologies for the lack of quality. There is a lot of fine metallic dust coating the inside of the cover plate as a result of the rubbing. I guess the bearing has been binding on the guide tube but funny thing is before assembly I checked the fit of the bearing over the tube and it was fine. I can't for the life of me figure out what's caused this. The only thing I didn't do was grease the guide tube but I'm not sure thats called for. (If it is........I'll get me coat )If I can get away with just a new guide tube and release bearing I'll be happy but if there's anything else I should look out for I'd welcome your response. ![]() ![]() (PS everything else fine, clutch fork not cracked, flywheel good, no oil contamination, engine/transmission mounts good , new cable, helper spring, spigot bush etc etc)
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
I'm not sure I believe that binding of that guide tube and throwout bearing can cause a judder ...
There may have been burs on the inside of the new bearing, and it may not be related to the judder!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
