-   -   Problem installing Sucro headlight relay kit (http://forums.pelicanparts.com/porsche-911-technical-forum/240847-problem-installing-sucro-headlight-relay-kit.html)
Russ in VA 09-13-2005 06:20 PM
Before anyone says "do a search" I have just burned an hour doing just that to no avail. Either my car is unique OR I am just dense. Please read about my problem and help me figure out which one it is!
Based on the instructions that Marcus provided with the kit, there should be one fuse for low beams and one for high in the factory fuse box that are to be re-routed using his kit.
My '84 Carerra has FOUR headlight fuses: one for left side low beam, one for right side low beam, one for left high and one for right high
Ultimately, it seems that I should really have four relays to keep all these routed separately. Since I want to finish this tonight, I am trying to decide if I should:
A) route one side of the low beams through Marcus's relay and one side high beam through his other relay, leaving the stock wiring for the opposing side and thus reducing the load on the headlight switch to just over half of what it was stock
-or-
B) route both of my low beam wires out of Marcus's single relay and both of my high beams out of Marcus's high beam relay
I'm leaning to option B.
Any suggestions will be appreciated!
Thanks,
Russ
lagrassa 09-13-2005 06:24 PM
Given your options, I'd do B. That is eesentaily what is done when there is one fuse per high beam and one fuse per low beam. I have done this to my '70 T and it works great.
Nathans_Dad 09-13-2005 06:25 PM
How long did it take to get your kit? I paypal'd him about a week or so ago and haven't heard anything by e-mail...
Russ in VA 09-13-2005 06:28 PM
Well, I bought it about a year ago but it seems like I got it pretty quickly. Obviously I was not really in that much of a rush so I might have been a week or two and I would not have noticed!
RoninLB 09-13-2005 06:48 PM
if you want the safety of all seperate circuits buy another 2 relays.
jyl 09-13-2005 07:10 PM
I think I did B on my Carrera.
FrayAdjacent911 09-13-2005 07:18 PM
I don't think there'd be any harm in bridging the circuits (connecting both the left and right circuits) , unless the wiring is old, and could overheat.
It would be safer to separate them and use a relay for each side, though. That's probably how I'll wire mine up when I get a round tuit. Probably when I get around to doing the H4 upgrades... but I much much work to do before I get to that point!
RoninLB 09-13-2005 07:37 PM
member bell did a nice post on the 4 relay install.
I use only 2 relays and carry a spare relay and bulb.
'78 SC 09-13-2005 09:01 PM
Yeah, option B. The fuses are bridged on one side (the side originally wired to the headlight switch), so all the current will flow through the relays, but lights will be individually fused (one fuse per filament).
The current load should not be a problem. Even if you installed 100 W hight beams, the current through the relay would be less than 20 amps (100 W / 12 volt x 2 ). What are the Sucro relays rated for?
deoxford 09-13-2005 10:34 PM
Russ,
Can you tell em more about this kit, what it does and were to find it. I think it sound like it will fix my headlight prroblem.
Wil Ferch 09-14-2005 02:16 AM
78SC:
OK...so you're up to about 20A with a 100W bulb, but the possible problem won't be with the "cube" style relays...mostly rated at 30A or such..it will be the wire gauge from the fuse box to the headlights. I'm not in front of my notes at the moment, but 100W would be my self-imposed limit with this set up and wire sizes.
To the original poster...you can go with B.) where a input power goes to a pair of headlight fuses ( either low-pair or high-pair as Marcus Sucro suggests in his install write-up). Of course, 4 is better.
For those going with monster wattages...don't just upgrade the power feed wire gauge to the lights...upgrade the return ground wire size too...otherwise you've done less than 1/2 of the job.
Wil
'78 SC 09-14-2005 05:03 AM
Wil,
Absolutely, you have to take a whole system view. I don't recall the existing fuse ratings; is the wiring (including grounds and sockets) adequately protected if you stay stock from the panel out?
Wil Ferch 09-15-2005 08:06 AM
yep.....
Wil
Joeaksa 09-15-2005 09:12 AM
Good thread!
Jadams1 09-15-2005 09:19 AM
Here's another link to a two relay setup wired for 80W/100W H4's.
http://forums.pelicanparts.com/showthread.php?s=&threadid=154585&highlight=headli ght
DW SD 09-15-2005 09:28 AM
Go with option B! That will be fine. Remember, in your stock setup, though you have individual fuses, they all are still switched through the headlight switch, which is what you want to avoid. Two relays absolutely avoids using the headlight for switching larger currents.
Doug
steve911 09-15-2005 09:52 AM
When I did the Sucro relay install, I also added an inline fuse between the battery and the relays. It was suggested by RoninLB in this thread . He suggested a 25A fuse.
911S Targa 09-15-2005 10:07 AM
I used 4 relays when I did my upgrade to 80/100Watt H4's
Mysterytrain 09-15-2005 01:38 PM
Ok, so I'm wondering why not use one 5 pin relay? 87a, the normally closed postion would be the low beams and 87 when energized would be the high beams. You would need to run one wire up to energize the relay, most likely in my case the connection from fuse 8. [which is also the feed for the dash indicator lights. Am I missing something with this method? If the 100 watt bulbs are your max then each headlamp would be drawing about 8 amps..so figure about 16 amps total on the high beam contact (87) and 85 watt low beams would draw collectively about 13 amps on 87a. This is all based on 13.5 volts. After looking at all the old threads on this subject and the pano article I'm also that the power sourced from the battery should be fused before the relay or relays and again on each feed to the bulb filiments..so four fuses on the relay outputs. Ok, smack me around on the one relay method??
RoninLB 09-15-2005 05:16 PM
creativity and personalizing is what our cars are about imo.
meanwhile, the normally closed lows would be on all the time, even when parked.
my bright idea was to trigger both high and lows in the Hi switch position. Both filimints overloaded the single common bulb ground.
Both left & right went kaput within 5min of each other. This all happened on a black road with no moon as I was testing my bright idea. Other than the kaput part, both filimints on at the same time seemed pretty nice.
'78 SC 09-15-2005 07:29 PM
It looks like we fall into two camps: 1- "I don't want to have to buy a replacement dimmer switch" and 2- "I feel like trying a bit of nighttime photography of the Grand Canyon".
Two relays (like the Sucro kit) is probably the ticket for the former; the latter are looking at four relays, upgraded wiring, new sockets, improved grounds, etc.
RoninLB 09-15-2005 10:19 PM
High above a high mountain valley on a down hill open twistie and overlooking miles of pines in colored fall looks better with really high watts.. btdt
The expanse of the canyons demand big watts for pics imo. More even than what I have. So I have 2 100w rally lights ready for the install.. I don't think it'll do much for the high desert canyons except road light. Road light in that area demand big watts for nice cruising thru the large expanses. I figure doing 80-90 on two lane beat up narrow swooping demand doable big headlights to see the full curve.. btdt with stock bulbs and big watts.
And.. I always figure that building electrics is open to many options. Pick your option.
fwiw.. i like tinned wire. Then Warren posts about E-code wiring that has silver plated with nice Teflon insulator.
Guess whats in the rear of my cruller every time I look at a new 911 elec project?
The below pic is another situation where really nice lights can make a difference. It was just a few seconds after sundown for the pic. The only light was reflecting off the past sun into the snow flakes. The pic is one thing. But big watts allowed the Montana N to S spring ride, in light snow, thru high hills, with great side to side views, to be a really nice 8 hour ride.
http://forums.pelicanparts.com/uploa...1126847973.jpg
Mysterytrain 09-16-2005 05:27 AM
Duh, your right about the contact always being hot..duh! Thanks Ron. I've been digging around for a nice four blade fuse box to mate up with a "pair" of relays. I would love to find some chassis mount relay sockets a make a nice little panel for all this stuff. Stay tuned.
RoninLB 09-16-2005 05:49 AM
check out West Marine catalog. When you find an item that's "close" go to the mfg site.
fwiw.. as one of those "while you're in there" things I ran a Blue Sea System panel w/8 vapor-proof CB's on the floor next to the battery. CB amp ratings are all optional and can be changed to another rating as things develop. The CB's are magnetic , not heat tripped. It's an obvious non Porsche item but it's real nice anyway.
RoninLB 09-16-2005 05:56 AM
this is in the engine compartment without fuses
http://forums.pelicanparts.com/uploa...1126875415.jpg
stlrj 02-06-2006 11:31 AM
Don't you mean Option A?
Since the two low beam fuses and the two high beam fuses are already bridged internally in the fuse panel, all that is needed is to remove the yellow wire going in from the top of the fuse(low beam feed), routing it into the low beam relay terminal #86 and reconnecting a wire from #87 as your new feed for the low beam bridged fuses.
You can do the same with the white wire(high beam feed) that feeds the top of the two bridged high beam fuses, disconnecting it from the top of the fuse and routing it into the high beam relay #86 and routing a relay wire from #87 to feed the bridged high beam fuses.
In addition, you can connect to a fused 12V battery source already available when you connect to the bottom of fuse #1 in your fuse panel eliminating the need to provide an additional fused connection from the battery terminal for your relay terminal #30.
Cheers,
"Joe Electrician"
stlrj 02-06-2006 11:43 AM
http://forums.pelicanparts.com/uploa...1139254963.jpg
Cheers,
"Joe Electrician"
HarryD 02-06-2006 07:23 PM
I did mine this way:
http://forums.pelicanparts.com/uploa...1139282596.jpg
ZOA NOM 02-06-2006 07:44 PM
Here's a thread with my 6 relay method. It results in independent high beams, low beams, and driving lights.
Here's the circuit drawing:
http://forums.pelicanparts.com/uploa...1139283879.jpg
HarryD 02-06-2006 08:27 PM
Gee Zoanas, are we going to have a posting contest ;).
If they look at your orginal post (http://forums.pelicanparts.com/showthread.php?threadid=263709) with this drawing they will see the pros and cons of both designs. Further comments can be seen here: http://forums.pelicanparts.com/porsche-911-technical-forum/259846-sucro-relay-kit-post2394682.html#post2394682.
As I state in both places, I do not think either is wrong just different and meeting two slightly different needs.
ZOA NOM 02-06-2006 08:54 PM
Yeah, it's ON, Harry! :)
As you mentioned in the other threads, and I agree, there are many ways to achieve a goal. I have to say, after a week of night driving with my setup, I couldn't be more pleased with the results. The combination of high beams with the Hella 450 driving lights is spectacular on the back roads I drive to/from work.
