}{arlequin's Avatar
front wheel bearing install?
I'm about to get into replacing the front bearings, and I'm not sure what to expect. Normally, the outside bearing just falls out on its own, usually when removing hubs/rotors. How about the inner bearing? Is it a press fit that requires a bearing puller? Hot/cold method to install? What about bearing seals?
thanks
dave
1973,5: one two thweeee!
no.don't.stop.
Old 09-15-2005, 08:21 AM
Friend of Warren
Both of the races will need some assistance to install and remove. The purists will claim that you will need to use a press or freeze the races and heat the hub. I just hammer them in and out with no ill effects.
Kurt
2003 Boxster S, 1991 BMW 318is
'93 Ducati 900SS, '76 BMW R75/6, '73 350 Honda Scrambler, 2003 SV650 Track bike
Gone, but not forgotten: '86 Carrera, '72 911E, 2001 Boxster
Old 09-15-2005, 08:31 AM
Par911's Avatar
What Kurt said, I just hammered my new races into the hubs last week.
Old 09-15-2005, 09:11 AM
Grady Clay's Avatar
Dave,
This project is conspicuous by its absence from 101_Projects.
Be very careful with the metal brake pipes. Always use two flare-nut wrenches and lots of penetrating solvent.
First off, keep the bearings associated with where they were installed if you are going to reuse them.
The inner (larger) bearing is held captive by the wheel bearing seal. Don’t forget to install the bearing before installing the new seal.
When removing the outer bearing races that are pressed into the hub, use a large pin punch ground at a slight angle and go in from the opposite side of the hub. Be careful to not nick the bore of the hub where the bearing goes. If you do, remove any raised areas before installing the bearing outer races.
Later hubs have a notch cast in them to fully accept a puller. I see nothing wrong with duplicating that with a Drimmel.
An often neglected part of this service is the seal race. It is pressed on the spindle and has a very thin O-ring seal between the seal race and the spindle. You should replace the O-rings.
When you have the seal race off the spindle, carefully inspect the root of the spindle for damage or corrosion. You can usually buff this surface to a fine finish. Coat the spindle with grease including under and behind the seal race. You can have the seal race slide on when hot (100C). You want a slight swipe of grease on the new seal lip and the race.
I prefer the heat-the-hub & freeze-the-bearing race approach. I still use a hammer to seat the race in the bore of the hub. Never use the wheel bearing adjustment to pull the race in place. I coat the bore of the hub with grease also.
Even with new bearings, I clean them and lube with my grease. This allows you to inspect the new parts and insures nothing foreign from the manufacture or assembly is in the bearing. Fill the areas between the rollers with grease.
After cleaning, grease the thrust washers, adjusting nuts, pinch bolts and grease caps – particularly inside the cap. Check the condition of the pinch bolt, particularly the internal hex. Note the proper orientation of the adjusting nut.
The bearings should be adjusted with a little clearance, not tight. You should be able to feel it when the tire & wheel is mounted.
When reinstalling brake pipes, push the hex fitting back from the flare and grease the space between the nut and the pipe. Grease the threads also. Don’t get grease in the brake fluid area.
It is good practice to take some medium grit sandpaper and scuff the rotors and pads. Clean the rotors with brake-clean last thing before you install the calipers. Make sure the pads are clean and free to move. “While you are there” cycle the pistons in the calipers. Remember to put the calipers back on the correct side – bleeders up.
This is a good opportunity to clean the wheel studs and lug nuts. The nuts should spin all the way on with no resistance. I put a pretense of grease on the lug nut ball the wheel stud threads. Remember to torque the wheels and check the tire pressure.
Pump/test the brakes before driving.
It is good practice to check the adjustment and caliper bolt torque after a few weeks of driving.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 09-15-2005, 10:25 AM
MBruns for President
JeremyD's Avatar
As always - Grady rocks -
Let me please add just a few suggesstions. #1 your outside bbq with a internal thermometer makes a great "oven" to heat up the hubs. More likely won't get you in trouble with the wifey. 100+ degrees can be enough. Wear goves, oven mits (be careful with the grease again!) Do your banging close to the grill - the hubs cool down rapidly.
Stick your races - seperate the bearings from the races and number them - or keep them grouped - labeled - whatever - stick them in the freezer. If you don't seperate the bearings from the freezer and live in a humid location, condensation will form in the worst place - in the bearing when you pull them out.
Heating/cooling can make all the difference in getting them in/out.
Old 09-15-2005, 10:35 AM
Rick Lee's Avatar
Dave, I just removed my hubs and had Pari drop them off at that bearing shop in G-burg. It's was around $40 for them to R&R the new races.
2015 BMW S1000R
2017 BMW 330ix wagon
Old 09-15-2005, 10:36 AM
Par911's Avatar
Yeah Dave, if you want I can do that for you too. It's right up the street from my place. Let me know.
Old 09-15-2005, 10:44 AM
Breeang's Avatar
Bump
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!.
1977 911S 2.7 to spend money on
2006 Tundra for acting grownup
Old 09-15-2005, 10:48 AM
}{arlequin's Avatar
Grady,
LOL, I'm laughing b/c of the wealth of info that I just inhaled!
Thank you for a great thorough "checklist" of what else I should be mindful of.
I'm not sure I ever saw any race on my spindle when I had it apart in the past but I'll check.
For reference, is this what I'm supposed to have on the spindle?
(on spindle from the yellow strut)
thanks again.
dave
no.don't.stop.
Old 09-15-2005, 11:23 AM
Par911's Avatar
Yes Dave, the one on the yellow strut is the seal race that Grady is talking about.
Old 09-15-2005, 11:48 AM
911SCfanatic's Avatar
yes, that piece is what the seal rides on.
question: how easy is it to get that off?
Bill G.
'68 911 Ossi Blue coupe
Old 09-15-2005, 11:49 AM
Par911's Avatar
It's not that hard Bill, I used a hammer and a chisel to tap off my old seal races once the strut/spindle was off the car.
Old 09-15-2005, 11:51 AM
Bandwidth AbUser
Jim Richards's Avatar
Not bad, I did this when I bought a set of used 3.5" ear'ed struts for the purple car so that I could run S-calipers. And, I replaced the o-rings in question.
Jim R.
Old 09-15-2005, 11:54 AM
}{arlequin's Avatar
i've gotta do more inventory, when i ordered bearing seals, I'm not sure if this is what arrived. If I don't have them on my car currently, should I be installing them on the new struts?
dave
no.don't.stop.
}{arlequin's Avatar
not sure if i even have the o'rings, any idea what they are called or should i just search for "wheel bearing race seal o'rings"
dave
no.don't.stop.
Old 09-15-2005, 11:56 AM
Bandwidth AbUser
I'd be concerned if you didn't have them on your car now. But then, you typically only subject your front wheels to half the stress as compared to most others.
Jim R.
Old 09-15-2005, 11:58 AM
}{arlequin's Avatar
it's funny, you read along w/ all the technical posts and see the pics, and it all clicks and makes sense
then when it comes time for you to do it, all of a sudden i turn stupid and the simplest task requires explanation LOL
dave
no.don't.stop.
Old 09-15-2005, 12:14 PM
zotman72's Avatar
This is Grady here. I'm at Bill's house. We just got his PCA
Club Racer running for the DE tomorrow and the Club Race at Pueblo this weekend.
While he was tinkering, I looked in his Bentley and others. None even mention the seal race and O-ring!
A scarey thing is that it is possible to install the hub with the seal race missing. Of course the bearng doesn't seat properly and some combinations the rotor rubs one side of the caliper. I have seen cars drive in this way. Too many times the seal race is thrown away with the old strut and not have a new one installed.
You can see the spindle radii I am talking about. Those need to be free of damage or corrosion.
Dave, when I go through one of these discussions I try and cover every little detail. There are many who lurk who are much less knowledgable. I just wish they would ask questions.
Oops, got to go do some adjusting.
Best,
Grady
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 09-15-2005, 03:34 PM
Is it possible to get the seal race off the spindle without removing the strut?
Steve B
72 911T
Steve B.
1972 911t
1999 328is
Old 09-15-2005, 07:12 PM
Pari would knowabout that. My guess is that it would come off.
You could heat it to break it loose, but that would probably ruin the o-ring. Someonementioned to me once that these seal races are like $45.
Dave I have a bearing race install tool which also works for the seals. It's taper matches the inside of the bearing race and it helps you drive it in straight. If you put the race in the freezer,mine when it with just some light taps.
Its yours when you want to barrow it.
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 09-15-2005, 07:48 PM
