H5 question
Will H5s off of a '91 C2 fit my '81 SC without any problem?
Do I need to connect a relay or relays? Will it depend on the bulb? Thanks for the help. - Jorge
73 Porsche 911 2.8 RSR Tribute Viper Green 84 Porsche 928 S Project car 84 Porsche 930 / 73 2.8 RSR backdate project car 06 Porsche Cayman S 09 Porsche Cayenne Turbo S - |
Jorge,
I think they will fit. I'm not 100% sure. I have H5s on my early car. Relays are better, but as long the wattages are lower you should be OK. You may have to check the wattages on the bulbs and repost. Hope this little bump, with no conclusive information ;-) is helpful. Doug
1971 RSR - interpretation |
Hey Jorge,
I'm not an expert, but I think you'll need to cut your current plug adapters and fit new H5 adapters. That's how my H5's were fitted. However, i've recently changed them to the H4's. The H4's are much better and brighter IMO. You may also want to make sure that you can still get those adapters. I don't see them available from Pelican anymore.
Shayne '81 911 SC |
I put H 5's in my 86 and bought bulb fittings from Parts Heaven (used but perfect). I also think they should fit in with screws lining up fine.
Tony G 2000 Boxster S |
