GIBSON's Avatar
Help- '79 SC Vacuum line- photos
Just helped a friend R/R his new 1979 SC engine/trans. We resealed, cleaned etc. We found one vacuum line we could not identify and assumed (like fools) that we would find where it goes
when the engine was in place. Wrong. It's obviously a functioning line, I've included some photos. Anybody have any idea where it goes? The car runs ok, stumbles a bit at idle but once off idle seems to run fine. Thanks.
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 09-17-2005, 03:59 PM
19 years and 17k posts...
azasadny's Avatar
Is that the vacuum advance for the distributor? Looks like the same diameter (small) on my '74.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-17-2005, 05:52 PM
GIBSON's Avatar
Art, I was looking around the area the hose would match up to
in terms of length and found this port behind the cruise control vent port. I'm assuming there is vacuum to the cruise unit, this might be it. It's a perfect fit.....
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 09-17-2005, 06:15 PM
biosurfer1's Avatar
bruce...
how hard would the lines be to hook up after the engine was already in the car. i have ( i think) a vacuum leak and was planning on replacing them, but wasnt sure if it was a job that needed the engine to be out of the car...any thoughts?
also, if you can remember the line lengths and diameters, it would be a big help...
thanks!
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 09-17-2005, 06:28 PM
GIBSON's Avatar
Some of the lines would be easy, others you'd really have to struggle with. You'd want to remove the fan (the electric one), the A/C unit if you have one, and you would still have a difficult time with some of the lines. Some of the lines are fabric type, others rubber so you'd want to have both lines available.
I think to do a really good job you'd want to drop the engine, maybe a partial drop would help- you'd get some improved access but it would still be a struggle.
I don't know all the lengths but I could measure specific ones if you want. It's not my car but I can get to it easily.
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 09-17-2005, 06:52 PM
Heck, I’m only 5 not 71!
targa80's Avatar
The cruise control does use a vacuum line and also has a breather line.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 09-17-2005, 08:11 PM
