spring plate bushings
Hello, I have just purchased new bushing but they don't fit in either the cover or the torsion bar tube. From what I have found on the forum they need to be turned on a lathe to fit? Why don't they just make them the correct size to begin with? I see there are also Neatrix rubber available. How do they compare with respect to performance and wear? More importantly do they fit without customization. Why is nothing ever straight forward with this car?
Thanks, Joe
Old 09-18-2005, 09:36 AM
Jeff Alton's Avatar
Neatrix are fine. They fit easily right out of the package. They are not really an upgrade, more of a replacement part.
Jeff
www.turn3autosport.com
Old 09-18-2005, 11:18 AM
randywebb's Avatar
I think there are some different stiffness levels with the Neatrix. ...doesn't mean that _you_ want it stiffer, tho.
"Why is nothing ever straight forward with this car?"
- It is German.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 09-18-2005, 11:26 AM
Jeff Alton's Avatar
Randy, if I read you correctly, are you suggesting the Neatrix is available in different compostions?
Cheers
Old 09-18-2005, 11:40 AM
randywebb's Avatar
Yes - that's what shop told me a few years ago when I put them on my car.
Old 09-18-2005, 12:04 PM
billyboy's Avatar
It is German.
- randywebb
Easy now, you're not being very PC!
The red Weltmeister bushings are the work of the devil, IMHO.
My old car was so rusty there, that after I sand blasted the holes and epoxy painted them, the bushings were too small and I had to shim them .
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 09-18-2005, 03:44 PM
