juicersr's Avatar
Mounting '935'/RUF style mirrors
What's the best way to mount the 935/RUF style mirrors. Do you guys that have them bolt to the window sill alone from inside the door? Is this stable enough or should i use some sort of epoxy as well? Thanks
Old 09-17-2005, 06:58 PM
m325ix's Avatar
I fabricated plates which I glued to the mirrors from the inside and then drilled thru the door frame and attached to these fabricated plates via 2 bolts. You can use epoxy as well. I had to make the plates 'cause my mirrors were kind of hollow inside
http://www.mybuildgarage.com/author/carreraboy
Old 09-17-2005, 07:03 PM
aftermath's Avatar
what do these look like?
theamsoilguy@hotmail.com
Old 09-17-2005, 09:06 PM
juicersr's Avatar
Old 09-17-2005, 09:28 PM
Sameer's Avatar
I bought mine of Ruf and it came with an epoxy. Yes it is hollow inside. Had tham sprayed and used the epoxy. Waitied for one day for it t dry. Today you can sit on it and it wont fall off, thats how strong the epoxy is.
Speed Yellow 911 Ruf BTR Conversion
PCS Membership No: 266
Rennlist Membership No: 050315-5911
Ebony Black 2004 Jaguar XJ6
Titanium Grey 2003 Ford Focus
Old 09-17-2005, 11:48 PM
juicersr's Avatar
Mirrors
Thanks guys.... think i'll go the epoxy route as i'm not too keen on drilling through the window sill.
Old 09-18-2005, 12:38 PM
I have a set of these FS - I bought them without considering the fact that you need window frames on which to mount them...
Old 09-18-2005, 02:01 PM
Driving member
jester911's Avatar
I guess you don't really need to see behind you if you use those. Course if you go fast enough you don't need to worry about what is behind you.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 09-18-2005, 02:52 PM
