-   -   Help Understanding Motronic (http://forums.pelicanparts.com/porsche-911-technical-forum/241608-help-understanding-motronic.html)
75Carrera 09-18-2005 01:23 PM
I've been watching the threads about the 3.2 Motronics.
Since my recent motor install the tach has been acting up (sticking or just falling to zero) and has now stopped altogether.
I saw several possibilites in the threads but so far haven't found it. It's not a loose connection (at least not at the tach) and my battery is brand new.
It sounds like other things in the electrical system can affect tachs. Is that true?
Could it be something as simple as the voltage regulator? I thought it might be the tach itself and I suppose it still could be. Any ideas on the best way to chase this problem down without spending a bunch to have someone else do it?
Early_S_Man 09-18-2005 03:25 PM
Donny,
Monitor your system Voltage while driving ...
If it is outside the nominal range of 13.2 - 14.5 Volts, then tachs can behave in various st range ways.
75Carrera 09-18-2005 03:33 PM
Thanks Warren,
You have been a very helpful member.
Without a gauge to monitor how do you check it?
Hugh R 09-18-2005 03:59 PM
Some auto stores carry digital voltmeters that plug in the lighter.
Early_S_Man 09-18-2005 04:12 PM
Donny,
It doesn't have to be done with a permanently-mounted gauge.
Analog or digital multimeter can be used with dedicated special test cord going from banana plugs to 12 Volt accessory plug, as in the pic below.
http://forums.pelicanparts.com/uploa...1123126225.jpg
75Carrera 09-18-2005 04:19 PM
Just what I needed to know. Thanks guys!
