-   -   Need some 101 Weber help (http://forums.pelicanparts.com/porsche-911-technical-forum/241626-need-some-101-weber-help.html)
Va914 09-18-2005 03:54 PM
I have a 2.2T with some weber 40's. (I'll get the weber specs tonight)
The engine idles overall fine (an intake pop every now and again). I am test driving my car for the first time since the topend rebuild and it seems the WOT is not there?
I adjusted the throttle stop and have the carb plates just about 100% vertical, so it;s not that
At about 3000-3500RPM it seems to lose power and sounds/feels like it is losing a cylinder Pulls good until 3000'ish?????????
At idle it reves great.
What jets control fuel at WOT and Mid-throttle?:(
Fishcop 09-18-2005 04:24 PM
Sounds like they are not transitioning from idle jets to main jets properly. Ensure you have PERFECT float levels in the bowls, the emulsion tubes can also play a part, but it's generally the float levels.
RoninLB 09-19-2005 01:51 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/241359-vacuum-advance-carbs.html?highlight=carb
"What jets control fuel at WOT"
-------- mostly it's the main jets. The devil is in the details.
"and Mid-throttle?"
--------- it depends. The idles may stay dominant till around 3.2k rpm. the mains take more control after that with the idles contributing less.
Grady Clay 09-19-2005 06:46 AM
911s (and 914-6s) with metal air filter assemblies can get rust
in the double wall chamber where the breather hose attaches.
Much of the rust particles are ingested by the engine. Some,
however, land on top of the carburetor and can restrict or plug
the main air correction jets (green). There are three of them
facing up in the carb (red arrows). If this is the problem, you
should see debris on top of the carburetor between the stacks.
IMAGE: WeberDiag01a.jpg “
http://forums.pelicanparts.com/uploa...1127137367.jpg "
© Dr. Ing. h.c. F. Porsche A.G.
Here is a view looking down on the carburetor. The three air
correction jets (red arrows) are easily contaminated by anything
on the carb top. The auxiliary venturi (green circle) is in the
direction of the air correction jet. Note that one float chamber
feeds only one cylinder (on left) and the other float chamber
feeds the center and right cylinders.
IMAGE: Weber_IMG_1165s.jpg
http://forums.pelicanparts.com/uploa...1127137438.jpg
Best,
Grady
Va914 09-19-2005 10:23 AM
Thanks. I'll check out the main jets and the fuel level.
I used the PMO float gauge before I installed the engine and things seem to be in line. Maybe something got into the carb :(
FYI:
I have an inline filter before the pump and then again before the Y-Block, but before the pressure gauge. I have the system set at 3.75psi. Could the pressure be dropping at WOT?
I just thought it was funny that I can rev the engine up to 6000 with no issues but once a load is on the engine....no go.
Cheers
Kerry (Back on the road, sort of)
jpnovak 09-19-2005 10:33 AM
I had issues on my ST with the fuel pumps not supplying enough fuel to keep the float bowls full. you could watch the pressure gauge go to zero under no load acceleration (blipping throttle). I assume this engine is in a converted 914 based on your signature. Check the fuel flow and fuel pressure under flow. Just a thought.
Va914 09-19-2005 10:36 AM
Yep it's a conversion :)
I have been setting the pressure at idle. I'll rev it up and see it it drops any.
jpnovak 09-19-2005 10:47 AM
You also need to check fuel flow volume. I think 100 L/hr was the Bosch rotary pump spec.
Grady Clay 09-19-2005 11:35 AM
FYI:
Cheers
Kerry,
I think you misinterpreted my post. These are the Air Correction Jets in the top of the carb, not the Main Jets in the carriers that go into the float bowls.
There are basically two running circuits in the carburetor – the Idle Circuit and the Main Circuit. Each has a main jet that controls fuel and an air correction jet that monitors air flow. In the Idle Circuit the main gas jet is known as the “idle jet” and is in a carrier at the upper side of the carburetor. The idle air correction jet is not replaceable and is pressed into the carb casting. The main circuit gas jet (Main Jet) is in a carrier near the bottom of the float bowel. The main air correction jet (Air Correction Jet) is the one pictured in my post above.
The engine will free-rev to 6000 on the idle circuit (mostly). As soon as you put a load on the engine, the transition to the main circuit is necessary. This doesn’t happen all at once and is moderated by the emulsion tube below the air correction jet. There are also several other things that affect transition from mostly Idle Circuit to mostly Main Circuit. Just off-idle there are ports that help that transition from idle to the idle circuit. This is an important difference between IDT, IDA and IDS. On the 40IDS3C carburetors there is a third “high speed enrichment” circuit. Then of course all have accelerator pumps that have a large affect when the throttles are moving open.
Your description sounds like you aren’t getting transition to the main circuit. This can be from a restricted Main Air Correction Jet causing the mixture to go very rich or by a restricted Main Gas jet causing the mixture to go lean. My bet is the air correction jet circuit.
BTW, the float level should be checked in situ with the engine at smooth idle.
Where is your fuel pump located? What kind? I wouldn’t use a fuel filter prior to the pump, just the in-tank screen filter.
There are aftermarket racing systems for an in-cockpit mechanical fuel pressure gauge. These have an intervening fluid so you are not exposed to a possible fuel leak in the cockpit.
Best,
Grady
Va914 09-19-2005 04:41 PM
DAM
I rechecked the floats and they are fine. Took the mains off and blew air threw them. Took the air correction tubes out seemed fine. Fuel pressure doesn't budge as I rev the engine (I didn't check volume yet) It should have plenty of flow, it is a new carter pump
Reassembled and took it out for a ride and SAME old thing:mad: :mad:
I have a 2.2T and weber 40's with;
Main's, 125
Idle, 55
Air correction, 180 and F26
Vent, 32
It idles fine and rev's great. Once I drive it and it loads up it has no power after 3000. Kin of hits a wall.
Do the Air correction tubes need to go in a certain way? They have a lot of holes on the side of them.
I guess I'll do more searching:confused:
RoninLB 09-19-2005 11:21 PM
JW says,
I've seen a lot of the T shaped primary/secondary venturis in backwards so they don't flow any fuel. the opening on the end goes toward the nearest emulsion tube. they go in either way. just takes one in wrong to create a dead hole as the Rs go up beyond what the idle circuit will run, like over 2500.
Fishcop 09-20-2005 12:20 AM
I'll echo Ron's reference to JWW... Check that the secondary venturis are correctly oriented. They are the green circle in Grady's photo.
Grady Clay 09-20-2005 05:31 AM
Kerry,
The Factory workshop manual shows the auxiliary venturi (red
arrow) installed incorrectly. The retaining spring (green arrow)
goes away from the air correction jet.
Installing them backwards will give the symptoms you describe.
This image is Fig. 42 on page F41 of the early 911 Workshop Manual.
IMAGE: WeberAuxVenturi01.jpg "
http://forums.pelicanparts.com/uploa...1127219366.jpg "
Best,
Grady
RetroSC 09-20-2005 07:05 AM
Did it run at WOT before the top end rebuild? If so, maybe you're cam timing is way off.
Another thing that happened to me was a bad coil. I replaced the coil during my rebuild and it wouldn't rev past 4500. After fighting the Webers it turned out a very weak spark from the "new" coil caused this.
Probably neither of these, but something to think about.
Good luck, Bill
Va914 09-20-2005 07:34 AM
This is my 1st time with this engine so I don't know about the pre-rebuild operation:(
The coil is a Crane PS-91.. Does anyone know if I can swap out the PS-91 with an OEM type coil, just to test the possibility of the above problem?
It just seems to run very well with no load.:mad: :mad:
I will retime the car tonight and HOPE it was off some. I will also set my fuel pressure back down to 3-3.5psi and change my vent's to 30's.....to see if that helps.
Also, someone mentioned I may need to "phase" my crane XR-700 in my dizzy. During the install I set the rotor to #1 (static timing) and timed the car as normal once it was running. No extra work was done.
dhoward 09-20-2005 08:38 AM
Is timing advancing as RPM increases?
Va914 09-20-2005 08:47 AM
IIRC, it (the timing mark) moves CW on the pulley so that means it advances.
Va914 09-20-2005 09:36 AM
Also, once I get near the 3000rpm range and it starts to act funny there are no backfires or popping????
Just the loss of power and a steady funny sound.
RetroSC 09-20-2005 09:52 AM
Mine revved fine with no load as well. It was just under load that the weak spark from the bad coil (actually it was the wrong coil for the ignition I had.. long story) and it would just hit what felt like a rev limiter at 4500. No carb popping or sputtering, just ignition misses like a rev limiter would do. That's what eventually led me to suspect the coil and stop fighting the Weber's.
Another thing that tipped me off to the ignition problem, was that I had to set the idle timing at 10 degrees instead of the normal 5. Just wouldn't run at 5.. another sign of the weak spark.
Just some things to keep in the back of you mind while fighting this.
Bill
Va914 09-20-2005 10:04 AM
Interesting about the coil.
I was looking at the cranecam website and noticed this:
XR3000 only. If a miss occurs
at high RPM, make sure any
ballast resistance has been
bypassed.
Does anyone know if I have ballast resistor?
RoninLB 09-20-2005 02:07 PM
Interesting about the coil.?
ditto
Does anyone know if I have ballast resistor? [/QUOTE]
afaik.. about the oldies it should depend on your stock ignition system? And more fun is that there are 2 ways to resist. Either as an external unit or as part of the coil.
And it's usually easy for me to figure whether fuel or ignition w/ carbs. I'll wack the throttle a few times till it starts to detonate. Then play with the edge of high detonation while watching in the venturis. It gets easy to figure after doing a few.
If you have to fake fixing the detonating engines it's probably safest to just remove the spark plug if it's a single cylinder or at least drive it with as little torque as possible imo.
If you have a single idle jet fully clog the combustion crashes, ie no ignition and no EGT.. and the CHT drops 10-30deg depending on conditions on the street. If it's partially clogged that means that there is ignition of a lean miss. Under load EGT will climb well over 1500degF. Lean miss CHT may not climb noticably when measuring w/plug gasket probe. You can also fake a wide open float by keeping it above 3.5k.
it's a carb eat mfi world.
}{arlequin 09-20-2005 02:24 PM
don't mean to hijack, and if it's too far off let me know, but I think this should belong in a thread about carbs.
I'm looking to get into this type of setup (recirculating w/ cis pump etc.) and I'd like to learn something from you guys. I know absolutely nothing about fuel pressure regulators. When I do a search, 30 pop up. How do you know what's a "good one" and what's not? Are there any established companies? (Mallory, Holley.... any others?)
What to look for when getting a FPR? Ability to rebuild is great, but what else? 2 port vs. 4 port? What's that mean- just how many attachments/hoses it will accomodate?
As for the fuel filters, I see many using the inline filters, which are nice. What's the micron rating that's recommended for this? What's overkill, but nice to have? Two inline filters of different sizes? Are both placed *before* the fuel reaches the FPR?
As for the fuel pressure gauge, many are mounted on the FPR itself, but I've seen some on a recirculating systems that are on the fuel line connecting boths sides carbs. Is that significant? Is the reading more accurate?
sorry for the barrage of questions, I've searched all over for some of these topics and figured that maybe I can gather them all in one place. If this is too much and requires its own thread, let me know (or cut-'n-paste and start another one.)
thanks.
RoninLB 09-20-2005 02:52 PM
Questions are easy. It gets tricker when you don't know what question to ask.
I picked up a comment about de-psi carbs w/using a dead head regulator. I'm currently looking into using a NOS jet out of Summit and plumb fuel from the carb psi side into the return line.
911pcars 09-20-2005 03:06 PM
"...I was looking at the cranecam website and noticed this:
bypassed.
Does anyone know if I have ballast resistor?"
Connect a voltmeter to the source voltage wire. If it reads about 9 volts (instead of 12V), you have a ballest resistor (or equivalent). The ignition box needs 12.
"Does anyone know if I can swap out the PS-91 with an OEM type coil, just to test the possibility of the above problem?....."
VA914,
I'm using the factory coil with my Hi6-S Crane box. Works fine. Coil is from my original 911T (same as 914-6) engine.
BTW, if after having checked all that was suggested, have you checked the fuel pump output? Fuel pump requirements under load are different than at no-load.
Sherwood
randywebb 09-20-2005 04:08 PM
PMO makes a good fuel pressure regulator. only about $40 so no reason to look further...
Va914 09-20-2005 04:34 PM
:D :D
Thanks guys.. I spent the few hours after work and recleaned the Main jets, installed the 30mm Vent's, adjusted the timing, lowered the fuel pressure (it was at 5.75psi), and plugged the missing vent lock bolt:eek: :eek: :eek:
Left the rain shields off and took her for a spin :D :
She runs very nice and the carbs sound so so so much better without the rain shields.
Thanks to all I am back on the road after just about a year of wrenching and paying:p :p :
rrichar 09-20-2005 05:52 PM
Grady,
Are you saying that all 3 auxiliary venturis will NOT point in the same direction? Just asking for clarification.
Grady Clay 09-20-2005 06:29 PM
Yes, they point in different directions.
I put a red line in the direction of the vent.
The retaining spring is on the opposite side.
IMAGE: WeberAuxVenturi03.jpg
http://forums.pelicanparts.com/uploa...1127266035.jpg
Best,
Grady
rrichar 09-20-2005 06:53 PM
thanks, I will have to check mine. I believe all mine point in the same direction.
I remember in some previous posts you had some nice things to say about Hal Shaw. Someday we should talk about Hal. I used to help him out in the Trans Am and Endurance races in the mid 70's.
RoninLB 09-21-2005 02:03 AM
I should have started with installing a fuel line and gauge between the engine comp fuel pump feed line and the return line. My stock return line currently has a back pressure of 6-7psi.
Either I had to install a new larger return line or design a system around that 6-7psi to get carb psi down to 3.5.
The other option was a 914-6 fuel pump which has a low psi discharge and is designed for carbs.
Va914 09-21-2005 06:01 PM
:eek:
Interesting issue has come up. Last night I drove the car and it ran fine. I pulled it in the garage and called it a night. I got home tonight to take her out for a spirited run and Blah.............CRAP
It turns out the dam water shields are causing the problems. I pulled over into a parking lot and removed the OEM water shields for the drive home. It ran great WTF:confused: :eek: :eek:
Va914 09-22-2005 03:15 PM
PROBLEMhttp://forums.pelicanparts.com/uploa...1127427292.jpg
What are these small filters used for?
