View Poll Results: What to do the these wheels?
Repaint the wheels white 8 34.78%
Paint the center black 6 26.09%
Polish out the wheel centers 5 21.74%
Something else (make suggestion) 4 17.39%
Voters: 23. This poll is closed
Wider is Better
wholberg's Avatar
Poll: What to do with these wheels?
I have a 87 M491 Carrera (see pic below). The PO repainted it a truly stunning Pearl White, and had the 3-piece BBS wheels painted to match. The problem is that the paint between the web is chipped in several places and is not starting to look that great close up. Also, between brake dust and oil residue, the white paint inside all the little holes is a real B**** to keep clean.
I am considering a few options for a winter project: repaint the white part on the wheels, paint the center black, or polish out the wheel center. I am curious what the opinions of other Pelicans are.
The car.......
A front wheel......
A rear wheel......
Wider is Better
Old 09-18-2005, 04:55 PM
IMO, the centers look good in white. I also think they'd look good in all silver.
If you go that route you may want to consider powder coating the color coat with a powder clear.
Warren & Ron, may you rest in Peace.
Old 09-18-2005, 05:03 PM
MBruns for President
JeremyD's Avatar
Al reed did mine - polished rims - powdercoated inside. I don;t have to worry about brake dust.
Old 09-18-2005, 05:21 PM
austin552's Avatar
White looks best to me on your car.
1974 911s
Old 09-18-2005, 05:36 PM
86 911's Avatar
Send a message via AIM to 86 911
I agree with Austin. White would look the best. Now if you want to look "extra bling", paint 'em gold. That's what's on my car now. The exact same rims, but gold. They look good on a red car, but a white car, I don't think they would...um... fit. Jeremy, your rims look great, and I think black rims like Jeremy's would also work great on your car. Nice 911 BTW!!
Matt
'76 Porsche 911 with '78 3.0 SC engine
'71 VW Bus
'14 VW Passat (toddler hauler & wife approved ride)
'03 Subaru Baja original yellow & silver
Old 09-18-2005, 06:00 PM
RETIRED
Joe Bob's Avatar
Flat black....ya won't notice the brake dust.
2012 ML350 3.0 Turbo Diesel
Old 09-18-2005, 06:26 PM
JeremyD's Avatar
I think they look good black - I like the black wheels on a white car
Old 09-18-2005, 06:30 PM
86 911's Avatar
Oh yeah! It looks a lot better black IMHO. A lot "meaner".
Matt
'71 VW Bus
Old 09-18-2005, 06:52 PM
project 911's Avatar
I did mine in graphite. Almost black, but with some metalic in it. I think it looks great.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 09-18-2005, 06:57 PM
Author of "101 Projects"
Wayne 962's Avatar
I have similar wheels on my BMW, you definitely need one of these - they make cleaning the wheels a piece of cake!
http://www.pelicanparts.com/catalog/shopcart/CARE/POR_CARE_CARAN1_pg3.htm
-Wayne
Old 09-18-2005, 07:39 PM
never ending projects
niner11's Avatar
I think that the black centers are a little much for a white car. Fuchs are the exception to that rule.
There is already a lot of contrast with black and white on the car so IMHO the centers would look best repainted in the same color that they are now or all bare aluminum.
Good looking care either way so you really can't go wrong. Good luck.
Old 09-18-2005, 08:29 PM
Question is; if you go white will the centers be all white or "windowed" with the silver faces. Interesting look.
Old 09-18-2005, 08:54 PM
JeremyD's Avatar
You guys that are saying white or silver have probably never cleaned a set of wheels like this - although the flow through brush sounds like a good idea that Wayne posted.
Old 09-19-2005, 06:08 AM
I've had a couple BMWs with the honeycomb centers. Not fun to clean but they look great when they are.
My routine would be to wet the wheels and then spray the with a foaming wheel cleaner and let soak for 15 or so minutes. Then wash the car. I'd use a bottle washer type brush to get through all the "fingers".
The trick is never to let the grime etch the clear. Once that happens it makes for a much harder exercise.
Old 09-19-2005, 06:37 AM
Wider is Better
wholberg's Avatar
Thanks for the ideas. I like the white, and I particularly like how the top of the web was polished. If I painted them black, I was thinking that I would keep the polished top. But for now...
SoCal911: I will try the low dust pads, thanks for the suggestion.
Wayne: I will also buy one of the brushes you recommended to see if that helps. Incidentally, I placed my first order to Pelican parts a couple of weeks ago. The parts arrived promptly, and overall I was very pleased with the transaction.
Wider is Better
Old 09-19-2005, 07:02 AM
