Targa_PB_78_SC
Ball joint wedge bolt seating in strut
I assume the wedge bolt should sit flush in the strut. I had a heck of a time getting the ball joint shaft into the strut.
Do I have a do over here? New wedge and new ball joint maybe? Or more pounding on it with brass drift and 5 lb sludge? ![]() ![]() ![]()
BareRearedRookie |
nope it does not have to be flush..you have it just fine.I did mine today and it is even more showing out;-)
btw to my surprise i have already did the bushing in the past-most likely back in 1996-7 when i got the 911 and totally forgot about it--way too many beers since then;-) Well, i did them anyway -not my favorite job thou;-)))))))))))) Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
When I changed mine, it stuck out a similar amount. I did a bit of searching, and it seems to be common. I have not had any issues.
Is replacing ball joints and tie rods a PITA?
Ed 1973.5 T |
The 9 Store
It’s a wedge. Doesn’t matter how much is showing as long as it’s doing its job. There is torque measurment.
All used parts sold as is. |
