-   -   Flasher Relay Location (http://forums.pelicanparts.com/porsche-911-technical-forum/242166-flasher-relay-location.html)
bweiss1 05-12-2019 08:57 AM
Flasher relay
A tip for those trying to replace the relay. If you pull on the plug into which the relay connects, it will pop out and you can then use two hands to plug in the new relay. Would have saved me the hours I took trying to line up the relay with the plug.
