-   -   need some help (http://forums.pelicanparts.com/porsche-911-technical-forum/242259-need-some-help.html)
cfarmer959 09-21-2005 08:18 PM
need some help
is there any way to vacuum out or inspect the heat tunnels on a Targa for debris. I am talking about where the heated air goes once it has left the heat exchangers and went up through the "flapper" valve and before it exits in the passanger footwells. My car was in extended storage and I want to make sure there is nothing in this area before I start blasting heat through it and poss. start a fire or something else.
any help is greatly appreciated.
Chris
77' S w/ SC upgrades
01' 325I w/ ACS upgrades
Vincent Hill 09-20-2022 06:57 AM
Chris
I hate that no one answered you because I was thinking the same thing. One thing I plan to do is use a Borescope and look in there.
911obgyn 09-20-2022 07:53 AM
Powerful shop vac in reverse or blower in the footwell outlets, remove the flapper valve hoses and give it a blow job!
If there is debris in there you will know.
You may have to remove the footwell blowers if you have them.
Vincent Hill 09-20-2022 08:08 AM
Thank You. I do not have the Footwell outlets I bought some to install when living in DC but never installed them. Thanks for the ideas and removing the hoses and open the system to vacuum out makes sense to me.
