Vin-barrett's Avatar
1983 911SC vacuum advice needed
Hiya
I'm a new 911 owner. I was just pokin around the engine and found that my deceleration valve has been plugged. Is this common to do? Does anyone recommend putting this back?
I appreciate the help
Vinny
Old 09-22-2005, 07:56 AM
Formerly bb80sc
Vipergrün's Avatar
Many times the decel valve is plugged to solve a problem with a high idle, like at a stop light with the car in neutral. The car will come to a stop and the idle will hang at 3-4K RPM's and may or may not come down.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 09-22-2005, 08:17 AM
jdowty3's Avatar
Depends why it was plugged. If it was sticking, as mine was, don't reconnect it. If it was sticking, you'll pull up to a stop and the idle will drop to about 1500 or so and may even start to rise.
The decel valve just lets the motor do a slower decel when you lift off the accel pedal. I removed the AAV and the Decel valve and left only the AAR.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 09-22-2005, 08:19 AM
Thanks for the replies fellas
Im going outside right now to stick it on and see what happens
Old 09-22-2005, 10:06 AM
Just plugged it in and yea it sticks. Seems to come and go though. Any thoughts on spraying carb cleaner in there might help?
Thanks again
Old 09-22-2005, 10:33 AM
