Question Will this 930 stuff fit my 2.7? Turbo quest continues...
I found this batch of parts off of a 79 turbo. I was looking for the bae kit, but no go so far. Will this work?
Image Hosted by ImageShack.us
Old 09-22-2005, 05:24 AM
Crotchety Old Bastard
RarlyL8's Avatar
Yes, all that exhaust stuff is a bolt on. I presume you have a plan for the intake side and the oiling system. That system is not optimal but it will work.
Old 09-22-2005, 05:52 AM
beepbeep's Avatar
It would bolt on but turbo will sit too low and you motor doesn't have auxillary turbo oil-pump so you won't be able to evacuate oil from turbo oil-drain.
It looks like usual thermal-reactor stuff with thermal-reactors removed and converted to "header"-logs.
I personally wouldn't bother with it.
Thank you for your time,
Old 09-22-2005, 06:30 AM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
930 cat-bypass pipes sell for $50 on eBay, they bolt right up to the stock 3.0 style exchangers.
Find an old turbo and muffler and you're golden.
Those old exchangers are a step backwards IMO
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 09-22-2005, 08:24 AM
