Jascha's Avatar
Steering wheel wobble
Howdy...
My steering column (shaft) started to wobble (12 to 6 o'clock direction) and behaves as if the bushing (or is it bearing?) is loose.
I recall that there was a simple fix (replacement insert or ?) that does not require taking apart the entire steering column assembly...
Many Thanks!
Old 09-22-2005, 05:30 PM
Driver Ed's Avatar
You've got the right diagnosis. It's exactly the symptom for a steering column bushing, which is an easy and cheap fix. You can find the part here or by searching for "steering wheel column bushing" here on Pelican Parts website.
Ed
2000 Porsche 911
1982 Porsche 911 SC Targa
Old 09-22-2005, 05:39 PM
I'm with Bill
Rick V's Avatar
I just did this same repair last week on the SC. It was so cheep and easy it almost didn't seem to be a Porsche repair.
Old 09-22-2005, 05:42 PM
Barrpete's Avatar
It sounds like the bushing. The original is plastic & disintegrates with time. It can be replaced for a few bucks with a metal one from our host. It did it on mine (1986) a few months ago - just pull off the horn pad - carefull not to break the wire. Unbolt the steering wheel & slide it off the column then slip the new bushing over the column & slide it into place & reassemble. Takes about 20 minutes. A word of caution - when unbolting the steering wheel don't let it turn so that you run the rack all the way to the end as that can damage the steering rack. Do a search & you will find several threads on this topic.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 09-22-2005, 05:43 PM
What?
trj911's Avatar
You've got it and we have all had it. Fortunately it is an easy repair.
Tom J.
911SC Cab
SCWDP
CaymanS
Old 09-22-2005, 05:44 PM
Jascha's Avatar
What a knowledgeable Chorus...
Question: Did you ‘drive-in' a new rubber bushing or just used the metal sleeve that Pelican sells...?
p.s. found the page...
http://www.pelicanparts.com/techarticles/911_Steering-bushing/911_steering_bushing.htm
Great solution!
1995 993 ('Under my Care')
1989 911 ('Go Pitt')
1996 993 ('Go Navy')
1984 911 ('Go Pelican')
Old 09-22-2005, 05:51 PM
Oh Haha's Avatar
I ordered a new quick-fix sleeve for mine when I got my rack spacers.
Went to install it and there was no plastic bushing. Apparently, the PO had already done this fix. I didn't really have a problem but figured to have it on hand and look anyway.
Pacific Blue
Wayne
Old 09-22-2005, 06:57 PM
steve911's Avatar
Great solution!
Jascha--
I did this last summer, using the metal sleeve (believe it has a 928 part #). It just slipped right in -- didn't have to use any excessive force at all.
When you take the steering wheel off, you may or may not find the remnants of the old bushing. If there are still pieces, pull them out using a needle nose pliers. Articles I read said don't sweat it if some of the pieces fall down into the steering column.
Like Rick V said - quick and easy.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 09-22-2005, 08:35 PM
