Jack Gresham's Avatar
Front brake cooling kit install pics
Here are a few pics is case anybody is getting ready to do this mod. It went smooth but, I was unable to repack the inner wheel bearing because of fear of messing up the grease seal, the Bentley manual method of using a screwdriver may have destroyed it in the process and the P car dealer just sold his last two seals, my DE is Saturday, and as JeremyD said, it might not be too smart to be messing with it on Thursday. I also learned it is necessary to disconnect the brake line on the front caliper to remove it on a 87 Carrera, I had to bleed the brakes for the DE anyway. I also installed Hawk blue pads.
Jack 87 Carrera
Old 09-23-2005, 04:00 AM
Very cool, Jack. Thanks for the excellent pics! May I ask what conditions, specifically, prompted you to go this route? The reason I ask is that my SC (reasonably light, but no featherweight) is experiencing no brake issues with track-only pads ...so far. Probably because I'm still using street rubber, but when I go to R-compounds and get faster, I'm hearing that will all change. Thanks!
Edward
993: retired Trackmeister, now daily driver heaven
911SC: resident Trackmeister-in-progress
Old 09-23-2005, 05:28 AM
Wavey's Avatar
Yes, thanks Jack - nice to see how everything fits.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 09-23-2005, 05:38 AM
GeorgeM's Avatar
Hawk Blues huh... You won't have brake dust, you'll have metal shavings, so make sure you use plenty of water when you clean them so they don't get scratched up.
You'll like the way they stop though.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 09-23-2005, 07:46 AM
zotman72's Avatar
Get some baling wire on the scoops as the zip ties will eventually break due to vibration and their brittle plastic nature. Use the same holes as the zip ties. Especially if you might do an off-track excursion at the DE. I have a set of these on my '72, it is a reasonable good setup for cooling but you have to clean out the debris on a regular basis as it will eventually make it way up into the center of the hub and produce a rattle (pebbles, tire strips etc.) HTH.
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 09-23-2005, 09:21 AM
What about a filter/screen on there?
Old 09-23-2005, 10:18 AM
MBruns for President
JeremyD's Avatar
I've had mine on for several years now and still have the plastic zip ties - and have never picked up anything of consequence and I've done an off track excursion (actually my buddy driving my car )and just bent the lip down a little, did not break the ties...
Looks good Jack
Old 09-23-2005, 10:52 AM
JeremyD's Avatar
Edward
Sebring is tough on brakes - hope this helps you get rid of your mushy pedal....
Old 09-23-2005, 10:54 AM
skinnerd's Avatar
I actually replaced the supplied wimpy zip ties with some huge industrial strength versions. They will never get ripped off.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 09-23-2005, 01:06 PM
Noel's Avatar
My scoops are actually metal, but these look like fiberglass. I wonder how well they hold up to off track excursions?
BTW, I hope you don't plan to drive on the street with those pads. They will eat your rotors alive. However, I find that they are not bad on rotors at the track (ie When hot).
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 09-23-2005, 01:17 PM
skinnerd's Avatar
I had a set of the original Holbert fiberglass cooling ducts that I used club racing for a number of years. When I just went under the car recently to redo all the brakes, I noticed that there was vitually nothing left of the scoops that hang of the front suspension arms. So I ordered a set from AlanJohnson that are made from aluminum. They were really nicely made....so I pulled off all the old fiberglass cooling parts (including the backing plates that funnel the air into the rotor center), and installed the new aluminum parts. Nice improvement. And they should last a long time as well.
Doug
Old 09-23-2005, 01:31 PM
Gasoline User
1974carrera's Avatar
That looks great, Jack! Have you had brake cooling issues or just being preemptive? Maybe I missed it, but what kit did you use?
I'm headed down to the DE at Sebring in the morning, so maybe I'll see you down there.
NICE looking wheelwells by the way!!
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 09-23-2005, 01:51 PM
