-   -   What does a PPI consist of? (http://forums.pelicanparts.com/porsche-911-technical-forum/242492-what-does-ppi-consist.html)
PcarPhil 09-23-2005 04:37 AM
What does (or should) a PPI on a 911 consist of? I did a quick search and didn't find an answer.
Also, what is the going rate for a normal PPI on a 911?
I'm looking for specifics. Check for rust, look at condition of suspension bushings, etc. Basically a checklist of a complete PPI.
Thanks for the help,
-Scott
MobileWrks 09-23-2005 09:14 AM
Top to bottom. If anything is worn or old, should be noted..
Also some have the valve covers pulled off to check for broken head studs. Some also do a comp. test.
1.0 ppi
1.5 with comp.
2.5 hours to do all the above
RickM 09-23-2005 09:21 AM
In addition to the suggested compression test you'll want a Leak down test as well. Have them document the results of each.
You want the body and other "non-mechanical" structures inspected by an expert who is very familiar with the 911 as well. He'll should be able to read the history of the car like rings on a tree.
BTW, a carfax is a nice added touch as well.
kstylianos 09-23-2005 09:22 AM
From one of our own, Matt DeMaria.
Very complete list:
http://www.dorkiphus.com/porsche/showpost.php?p=25877&postcount=10
Jack Olsen 09-23-2005 10:45 AM
Another view from Pete Zimmerman, here.
PcarPhil 09-23-2005 01:47 PM
Thanks guys. This is exactly the info I was looking for.
-Scott
