			After just getting my car back from being stolen, I am quite paranoid about it getting stolen again.  What are the best options to keep my baby safe?  I was going to get an engine cutoff switch eventually as she is a part time track car.  Can this also be an effective theft deterrent?  If not, what is a good alarm system to use?  Would it be good to use both?
				Thanks, Justin
	'84 Carrera 911 euro (Guards Red) "Jessica"  |
			 Slippery Slope Victim
			I've been thinking about a remote cut off switch to the fuel pump.  I'm just concerned about any electrical gremlins that might develop because of some electrical phenomenom in the system.  I used to use a cut off to the fuel pump in other cars with carbs,  the car would travel 500' and stall,  what does a thief do now in the middle of an intersection?
	MikeČ 1985 M491  |
			I have the same question. I have a 74 so the fuel pump is not on a relay or fuse. I was thinking about installing a simple switch to interupt the current to the fuel pump. I'm not sure if I'm suppose interupt the positive or negative?
	Anyone????  |
			 Driving member
			A battery or fuel cut off would be my choice. When is the last time anyone payed attention to a car alarm. Most people(including me) just get annoyed.
	Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.  |
			A layered approach is best. Layer the sh it out of it if you're doing the install.. all imo.
			If you figure the crook knows what he's doing feed him some bait so that he can beat feet easily. Then shoot him in the middle of traffic like Mike said. That is the best technique according to a NYC PD Auto guy's words to me informally. They dump it as quick as possile. And if he knows what he's doing he knows about killing the fuel pump relay/ like all alarm installers do, knows how to jump the starter/ like all wrenches do, and how to jump the CD box like he was told. that said.. many of these guys are 5th string in the brains dept. They know one or 3 acts then they're as confused as a 2nd grader. The best is when they bring a hottie into the same joint that gets busted 1-3yrs historically.. no matter who owns it.
	Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6  |
 I can build them strong enough to last longer than a rebuilt engine. And figure in a 2min relay jump just in case something strange happens.
			Hi,
			I have a Clifford System III (not avail anymore). Was put in when car was new back in '84. I love/hate it. Love: Keypad - can't scan the code... Been very reliable. It has Shock/vibration sensors as well as cutoff (not sure anymore what it cuts). Also has a battery back-up in case the battery is cut - but there is a solinoids lock on the front bonnet that needs to be released. Hate: It has two horns. One in the front bonnet, one in the cabin. My dad bought the car new and the horns scare me to death. I now have the car and still hate the screeming sirens. I believe they are 120db horns. The car has had it's small side window(a-piller) broken only once a long time ago. I wish they still made something like this. Some of the new alarms have the ability to beep you within a few hundred yards... BTW, Hooking up a capacitor system (50,000 volts) the door handles does wonders! Just remeber to turn it off before you grab the handle! Dave
			Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD Last edited by slodave; 09-26-2005 at 10:54 PM..  |
			[QUOTE]Originally posted by slodave
			[ BTW, Hooking up a capacitor system (50,000 volts) the door handles does wonders! Just remeber to turn it off before you grab the handle! That is awesome, how can i do that to my car?
	Joe 2008 Toyota Prius 1978 Porsche 911 sc targa SOLD  |
			Hi,
			I've not personally done this - yet.. But I do know that it has been done. I do know someone that has done this. I can ask, but I hold no responsibility with the outcome. It works very much like a stun-gun. Does not take too much voltage up front, the 12v battery can be used. You do need some capacitors, a calculator (Need to produce high voltage with low current (amps kill people, not voltage)). Just need good insulated wire and a good arm/disarm device. It is not fun being hit with 50,000+ volts. Dave
	Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD  |
			it is also not fun having your car stolen..
			Hi,
			Not going to go into the whole story, but I know how it feels and more. The carrera has always been fine, but not so fortunate with an Infiniti... I'll get the details, but it'll take a few days. Dave Dave
				Ignition cutoff
			See Tech article which is a simple way to ground the coil, using cable lead which already goes to the dash area, for the tacho.
			This may only apply to certain generation cars where the wiring applies. http://www.pelicanparts.com/techarticles/Mult_ignition_cutoff/Mult_ignition_cutoff.htm
	POKDUB Porsche 911E  |
			cool stuff, thanks for looking into it.
			I can't imagine that a thief would carry a key for an engine cutoff switch.  It doesn't seem like there are more than a few dozen cars in the area with them.
