plymouthcolt's Avatar
Ok to use denatured alcohol to flush evaporator?
Is it ok to use denatured alcohol to flush evaporator?
Also what should I use to clean the outside? I guess it would some sort of spray since I can't scrub it. The alcohol maybe?
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 09-29-2005, 07:13 PM
I went and bought a gallon of Mineral Spirits from my local hardware store (O.S.H.).
I used this per the Arizona Air (I think that's their name).
Good luck.
Nick
'85 Carrera
Old 09-29-2005, 07:41 PM
Wider is Better
wholberg's Avatar
If you want to use alcohol, isopropal alcohol is a better bet than ethanol, but mineral spirits will work too.
Wider is Better
Old 09-29-2005, 08:42 PM
Best flush on the market is sold by NAPA. It costs more than mineral spirits or alcohol, but is a much better cleaner and is easy to blow out of the system because it dries very fast. Its called Dura 141 and will clean the gunked up residues that get in all the nooks and crannies of your evaporator.
1980 911 SC
2017 Suburban
2022 Mercedes 450E - Wagon
2011 Jeep Wrangler
Old 09-30-2005, 08:22 AM
Thanks Jayt...I'll guess I'll pay more and not have to worry about compatibility.
Howard
2003 996tt
Old 09-30-2005, 08:27 AM
